24 volt battery; 1st charge 6 hr., lasted 1 hr. 2nd charge 12 hr. charger has NO green light. What do I do now?
SOURCE: 12 volt grass hog cordless
there should be 2 screw that holds the top cover.before that u have 2 release/remove the handle first.
SOURCE: 12 volt re-chargeable battery won't hold charge
Yepp, you can replace it..BUT...its more expensiv to buy a new battery then it is to buy a new hand drill...almost.
If you want to replace it i sugest you go to the store where you bought your hand drill and buy one there.
Good luck to you
Nic
SOURCE: I am having problems with the battery on my worx
You can determine exactly what is going on by using a small handheld voltmeter. They are inexpensive, easy to use and come in very handy. Just test the output of the charger (after noting what the volt-output-rating is) by touching the leads of the meter to the terminals on the charger. If the charger is working at all, this is not a dangerous test. Conversely, test the output of your batteries by touching the leads of the voltmeter to the terminals on them. I suspect the charger is bad because after they overheat, they quit working and some don't last very long. I don't think YOU are doing anything wrong, just maybe the companies that manufacture these 2 electrical products are.
SOURCE: bought unit last year...when charging
sounds as though the battery needs replaced, can check and see if it has a warranty on the battery. Hope this helps Tim
WE ARE ALSO HAVING PROBLEMS. THE TROUBLE SEEMS TO BE THE BATTERY'S OR
THE CHARGING SYSTEM.
THANKYOU. MRS SABATINO
PS. I WOULD REALLY LIKE AN ANSWER. THIS HAS BEEN AN ON GOING PROBLEM.
IT IS FRUSTRATING.
