If your projector is out of warranty and not covered by a repair plan, I found several sources for the replacement fan with a Google search. IFixit has some videos for taking apart the projector to clean it and replace the fan on some BenQ projectors.
Any one of the cooling fan inside the projector is not running. There can be two or three fans inside the projector.
If you wish to get some details; check the site linked here. Pull up older posts..... http://electro-medical.blogspot.com/
it could be the fan, colorwheel or high temp. remove the lamp and turn it on. do the fans spin? if not, replace the fans. does the colorwheel (colored glass wheel near the lamp) spin? you should be able to see it and hear a high-pitched whir. if not, replace the colorwheel. if the lamp was still hot when it was turned off, you need to let the fans run and cool. then unplug it, plug it back in and try again.
All projectors are cooled by the use of a fan. The light chamber has its owned fan to extract the excessive heat generated by lamp. Check to see if this fan, close to the fan is operating.
This is what your projector's user manual says about a flashing "TEMP" light :
"The cooling fan is not operating. Turn the power OFF and wait approximately 20 minutes. After the main unit has cooled down, please make confirmation that no foreign matter has become caught in the fan, etc. After performing any needed maintenance, turn the power ON again; if the same display is displayed, then please contact a sales store or a service company."
