Lines print in photos from the hp5512 have cleaned print heads, changed color cartridges light color lines print all through photos
Http://support.hp.com/us-en/search?q=HP%20Photosmart%205512&filter=
http://support.hp.com/us-en/product/HP-Photosmart-5512-e-All-in-One-Printer---B111a/5053904/model/5063610/document/c02914910
SOURCE: Black light & print cartridge
Unfortuantely , to solve the issue , sadly, yes you will have to replace the empty cartridge to continue to use the printer in a normal fashion. Its a sneaky and dirty trick many printer manufactuers do to make more money off of the customer through the purchase of printer ink.
SOURCE: I purchased a photo print
Could be that cartridge 31 is not compatible with your particular model. Please read the manual for a list of compatible cartridges. If it is compatible with your model, ensure that you have removed the backing plastic from the print head and fitted it properly into the slot.
SOURCE: Our Photosmart 7960 puts horizontal
I don't know if that printer has a cleaning routine on it, or not. If it does (check your documentation) I'd do that first. If that fails to clear things up, you may want to try to clean the print cartridges by hand. If you still have a problem, you'll probably need to get some new cartridges.
Hope this helps answer your question.
Ron
