I left an empty grill pan with larger base than hot plate that was on high heat for about 15 mins. this caused a red light to lit up. now the red light list up and there are some sparkling as we'll when i turn on the knob for that hot plate. all other hot plates are fine. Can this hob T1213 be repaired? or does it need replacing?
SOURCE: auto electric lighter for the gas stove no longer works
gud day,the problem is ur igniter ligther is totally damage & nid to replace, if u want to use ur cooktop use matches or ligther every time open ur gas cooktop,tnx gerbee
SOURCE: neff T1722 so 02 ceramic hob
its normal for the ceramic hob to ON & OFF coz of the sensor inside the unit to protect for overheating.same here in phillipines.its normal.tnx gerbee
SOURCE: left hand side not working
OK. I know whats wrong. On your terminal I guess you only connected the Large Brown wire to the number 2 terminal ( Live ) What you have to do is bridge terminal 1 and 2 together. You may need to peel back the heavy copper brown so you can split it evenly and ensure it can reach to terminal 1 and 2 . So what you have then is one cable feeding to both 1 and 2 terminal. If you have the smaller live brown wire just connect that to terminal 2 also. That should fix your problem. I will check back to see if you have any more problems..
SOURCE: left a empty pan on hot burner and glass top
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
SOURCE: I have just moved homes and never used a ceramic
If your hob is siemens then the controls are touch... press the on/off switch for power, then the control pad is yours with
