Nortel T7316E 2-Line Corded Phone Logo
A
Anonymous Posted on Jun 16, 2017
Line 1 function has been deleted from the memory key.
While trying to update time and user name of one T7316E phone, I have realized that the Line 1 memory key is no longer functioning, i.e. the ability to use Line 1 to dial outgoing call is now gone. While trying to use button enquiry, such key has no programmed feature. Can only use Line 2 to call out now, but no problem so far on incoming calls. Still very inconvenience to have only Line 2 to call out. Is there anyway to reprogram Line 1 back to such key?
5 Related Answers
A
Anonymous
  • Posted on Apr 17, 2008
SOURCE: Changing the time on a Nortel networks phone
Feature **time (type out time on the dialpad.)
bubba357
  • Posted on Nov 14, 2008
SOURCE: can't dial out
On my 9417cw this happened from time to time and I found a very simple solution. Disconnect the power supply for a few seconds and plug it back in....voila!
A
Anonymous
  • Posted on Jun 27, 2009
SOURCE: nortel t316e phone only rings 2 times
You could have a CICS, and MICS or a Nortel BCM. Which do you have?
You will need to access admin programming, do you know how?
Anonymous
  • Posted on Oct 22, 2009
SOURCE: changing name in nortel T7316E handset
We would like to change the name displays on our phones
consultel1
george peters
  • 860 Answers
  • Posted on Dec 08, 2009
SOURCE: Nortel T7316E Call Forwarding - Outside Line
The Nortel call forwarding (feature 4) is for forwarding the ringing and intercom from one extension to another.ex. if you were going to be working in the conference rm. instead of at your desk,with the forward on to the conference rm. extension, the calls you get at your desk will transfer to the conference rm. phone. Call forwarding through your service provider is done by accessing the telephone line you wish to forward, dial *72 (you should get dialtone reordered)and dial the telephone number to where you want the calls to be forwarded to. the party on where your forwarding the line to has to answer the line for the forward to take place. to remove call forwarding , access the line you have the forward on and dial * 73, you should recieve a stuttered dialtone for confirmation that the service is off
Need to program new phone numbers
The manual is available here: www.uniden.com/pdf/CEZ260om.pdf. If you search google for "uniden cez260 corded phone manual" it is the first result.
You can find the instructions in the fourth column of text under "Storing a Name and Number in Memory"
Here is the text from that section, but I can't promise the copied text is accurate. Check the pdf at that address if anything doesn't work.
1. Press STORE. LOCATION? shows in the display.
2. Press the desired memory location (0 to 9 or quick call buttons A, B, or C.) NOTE: Press LEFT or RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C to select a location.
3. Press STORE again to con? rm the memory location. NOTE: Use Delete to erase existing memories or to correct errors.
4. Use the number keys to enter the telephone number (up to 32 digits) and then press STORE to save. (The unit will not dial a phone number in this mode.) The cursor automatically moves to the text line for name entry.
5. Use the number keys to enter the name of the person associated with the telephone number you just entered. More than one letter is stored in each of the number keys. Press the keys multiple times to scroll through the letters for that key. For example, to enter "B," press "2" twice. Press LEFT two times to create a space. NOTE: The ? ashing cursor automatically moves to the next position or you may press LEFT or RIGHT to move the cursor to the next position.
6. Press STORE to save the name.
7. To enter another name and number in a di erent memory location, return to step 1 and repeat this process.
Storing a Pause in Memory
The REDIAL/PAUSE button has dual functionality and becomes a pause button when pressed in sequence after the STORE button. It is valid only when storing a number into memory locations. Use the REDIAL/PAUSE button to insert a pause when a delay is needed in an automatic dialing sequence (for example, when you must dial a 9 to get an outside line or when you enter codes to access your long distance company).
NOTE: A pause is 3 seconds in length and you can store more than one if a longer pause is needed. Changing a Stored Number Repeat the storage sequence under Storing A Name and Number in Memory, and press DELETE to delete the old number before entering the new number.
Erasing a Stored Name & Number
1. Press STORE.
2. Press the memory location (0 to 9 or quick call buttons A, B, or C) to be erased.
3. Press DELETE.
Copying Caller ID Memories to User Memory
1. Press LEFT or RIGHT to view the caller number and name you want to copy.
2. PressSTORE.
3. Press the memory location (0 to 9 or quick call buttons A, B, or C). The number ? ashes if there is a number already stored in that memory location.
4. Press STORE to enter Edit mode, and then pressSTORE again to edit the name. NOTE: Select a di erent memory location by using LEFT and RIGHT to scroll through 0 - 9 or quick call buttons A, B, or C.
5. Press STORE to con? rm and save. Wait three seconds to exit.
NOTE: If the name you want to enter is longer than 12 characters, only the ? rst 12 characters will be copied into memory.
Storing a Redial Number to Memory
1. Press STORE.
2. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If a number is already stored in the memory location, it will appear on the display. Use LEFT and RIGHT to select a di erent location.
3. PressSTORE again to con? rm.
4. Press REDIAL/PAUSE, and then press STORE again.
5. Enter the name, if necessary, and then press STORE to con? rm.
Copying a Redial Number to Memory
1. Press REDIAL/PAUSE while on-hook. Redial number will display along with PICKUP PHONE.
2. Press STORE.
3. Press any key (0 to 9 or quick call buttons A, B, or C) for the memory location. If there is a number already stored in the memory location, it will appear on the display. Use the RIGHT or LEFT buttons to select a di erent location.
4. Press STORE twice.
5. Enter name, if necessary, and then press STORE again to con? rm and save.
Dialing Numbers Stored in Memory
1. Press DIAL.
2. Press a memory location button or use LEFT or RIGHT to scroll through stored memory locations to ? nd the desired number. The number in that memory location displays.
3. Press SPEAKER or pick up the handset to dial the displayed number.
OR
1. Lift the handset or press SPEAKER.
3. Press DIAL again to dial the stored number.
If it is Blank button Terminal and sets ---> line access .....> line assignment and go to line 001 make apply or apply and ring it will come back
I cannot ring other phones in our office and my phone doesn't display when other employees are on the phone
Hi Kym,
It sounds like your phone might be a bit of a lone ranger! Try cloning someone else's phone settings to your phone and see if that solves the problem for you. You can do this by:
Feature **266344
Password: 266344
You should see Terminals and Sets. Press the Show button.
It should ask the for extension number, so enter the extension of someone whose phone is working properly.
Press Copy
It'll say "Copy SystemData" Change that so that it copies subscriber as well.
Press Next. It'll say Copy Single. Press Next
Enter your extension number when it says Copy to:
Once it has finished, hang up and give your phone a try once it has updated.
Hi We have a Nortel T7316E phone system. Staff
Programming is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344 (with the handset in its cradle).When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number.
Enter extension number you want to change the name on. (i.e 202)
Then press the show key (top right arrow)
The display should say LINE ACCESS
Press the next key (bottom right arrow) .
The display should say CAPABILITIES.
The display say Name(Traci).
press the Chng soft key.
use the dial pad to enter the name. advance using the arrow soft key to go to the next letter
ex. Winston = 9 -> 4,4,4 -> 6,6 -> 7,7,7,7-> 8-> 6,6,6-> 6,6
Press the next key (bottom right arrow) to enter the name.
Press the release key when finished
PROGRAM SPEED DIAL FUNCTION TO MEMORY BUTTON ON NORSTAR T7316
press feature * (star (shift 8)) 3, push the memory key (speed dial), then feature 0. This programs speed dial to that memory key.
I can't find the "show"
The "show" key would be the top right arrow of the 3 or 4 arrows on the display where the line and function keys are,
2helpful
2answers
I'm trying to disable paging on my T7316E phone. Paging is EXTREMELY loud and bothersome. There should be a function key sequence that disalbes it.
You can disable paging through system programming but it might be easier to turn down the volume by pushing the volume down arrow when a page is being announced.
7helpful
2answers
I have a T7316E Nortel phone and we have had a lot of employees chance. I need to change the display name for each phone. How do I do that?
Enter programming by pressing the feature key followed by **266344.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change the name on.
Press the show key (top right arrow)
The display say Name.
ex. Bill = 2,2 -> 4,4,4 -> 5,5,5 -> 5,5,5
HOW TO CHANGE NAME ON MY T7316E
Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
1.- To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
2.- Enter password (default = 266344) - display should read "Terminals & Sets"
3.- Press "NEXT"(bottom right arrow) 5 times - display should read "Time and Date"
4.- Press "SHOW" (top right arrow)- display should read "Hour:___"
5.- Press softkey "CHANGE"
6.- Enter hour - display should read "AM OK or Change"
7.- Select AM or PM
8.- Press "NEXT"(bottom right arrow) - display should read "Minutes:___"
9.- Press softkey "CHANGE"
10.- Enter minutes
11.- Press "NEXT"(bottom right arrow) - display should read "Year:___" 12.- Press softkey "CHANGE"
13.- Enter year
14.- Press "NEXT"(bottom right arrow) - display should read "Month:___"
15.- Press softkey "CHANGE"
16.- Enter month
17.- Press "NEXT" (bottom right arrow)- display should read "Day:___"
18.- Press softkey "CHANGE"
19.- Enter day
20.- Press "NEXT" (bottom right arrow)
21.- Press the Rls key
Trying to change the name on a phone
1. Press FEATURE * * 2 6 6 3 4 4
2. Enter Password: 2 6 6 3 4 4
3.Press the top grey button (the set on the lower right hand side with the grey buttons closest together)
4. press the button under the one you just pushed until you get the desired name/ or the one with no name
5.press the same button as in number 3 (once only)
6.press the same button as in number 4 (2 times) you should get the name and a soft key button for change
7.type the name like a text message
8. once you filled it in hit the same button as in number 4.
9. hit release
Top Nortel Lands Phones Experts
vince
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
