Samsung UN39EH5003 39-Inch 1080p 60 Hz LED HDTV [UN39EH5003] Logo
A
Anonymous Posted on May 24, 2014
Why won't my tv turn on - Samsung UN39EH5003 39-Inch 1080p 60 Hz LED HDTV [UN39EH5003]
Electro Med Services
Level 3:
  • Samsung Master 6,694 Answers
  • Posted on Jan 18, 2016
Samsung Master
Level 3:
Answers
6694
Questions
Helped
1870190
Points
21433
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site http://electro-medical.blogspot.com/. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
2answers
My Veon 32'' tv wont turn on
Usually fuse near cord interior in case. Teardown. Careful..VOLTAGE danger even unplugged. Touch nothing else.
2helpful
Vivo tv won't turn on lost the remote and the
These are the universal remote control codes to Vivo TV. 0004 0005 0009. Check this link to know more codes and proceedings to other brands of remote controls, and buy one remote control that has setup codes with your TV. The above said codes are for GE remote with Vivo TV.
Sansui tv won't turn on
Check its main power supply regulator section circuit for defects. Check and replace damaged component/s.
1helpful
Emerson tv....won't turn on...stand by light won't go off
Not making it on or out of standby---first place to look is the power supply for signs of damage or puffed up filter caps there.
My 22 inch Vizio flat screen TV won' turn on with
short of taking to a shop for an estimate most of these smaller screens get replaced versus repaired.
2answers
Tv won't turn on. Blinking in standby in red. Won't start
This is an indication of protection error and might require attention of a qualified service technician.
4helpful
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Tv won't switch to "tv"
Your T.V. is programmed to store the last input you've selected. You have to manually switch it back to your T.V. channel input after each time you switch it to HDMI or any other input even when you turn it off. The "Source" or "Input" button on your original T.V. remote will change this.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
