SOURCE: tractor sprinkler, (traveling sprinkler)
I made mine stay on by wrapping a plastic tie wrap around the shaft of the stopper between the stopper head & where the stopper shaft enters the housing. It must be wide enough to keep the plunger/stopper from going into the housing. Hope this helps. God Bless You!!! Darrell
SOURCE: Nelson Tractor Sprinkler goes slow and intermittently.
I dont know of a repair kit but it sounds like the motor needs replacing..and you can find the parts online at www.lrnelsoncorp.stores.yahoo.com i hope this will help
SOURCE: need parts
Have you tried their website? These sprinklers are relatively expensive units as I remember. Well made and well worth fixing. Usually nylon gears with stainless steel shafts. Parts should be available through Nelson. Google: Nelson Traveling Sprinklers and see what sites pop up. If this has been helpful, please rate it accordingly. Good luck.
SOURCE: Tractor is traveling backwards!!
there is no fluid or filters in transmission, Try turning the nozzles on the spray arms so that they point the opposite direction. If point the wrong way the tractor will travel backward
SOURCE: where can I order parts for a Neilson Traveling
Here are traveling sprinkler parts...
Sprinkler parts
heatman101
There is a seal by the push rod that stops the tractor that is leaking...
Here is a tip about how to
get parts for your traveling lawn sprinkler and also a great
article about how traveling lawn sprinklers work.
Traveling
Lawn Sprinklers
heatman101
