SOURCE: eureka bagless uno 12 amp ( green)
Buckaboo, you say the debris no longer collects in the cup? Does that mean you don't have suction as well?
The brushroll has it's own motor so the brushes spinning doesn't necessarily mean there's not a problem with the wiring, the switch, or the motor.
Assuming you haven't inadvertantly set the selector switch to floor when you wanted to use the hose or vice versa, try the following.
Start with the motor/impeller first. Take the dust canister off and turn the vacuum on. It doesn't matter if you turn on the brushroll or not as you're looking for suction.
With the vacuum on feel for exhaust out the front of the motor (by the secondary handle on the bottom. Also put your hand over the area where the dust canister sits. You should feel strong exhaust and suction respectively.
If not, then you should take it in to a technician as going any further requires disassembly.
If you feel there's enough suction, then it may be as simple as a clog. This vacuum has a particularly easy air path to check. There's a clear snap-on door on the bottom to check the brushroll and neck. Then from there it's a straight shot through the canister itself before dumping inside and going through the filter. If it's the hose, you can turn the end clockwise to remove it from the body of the vacuum and use a broomstick to clear any clogs.
If it's not a clog or filter then you may try cleaning the seals (one round at the bottom of the canister where the canister mates to the body and a rectangular one in back of that where the dust runs up and into the canister.
Good Luck!
SOURCE: Eureka Altima
The dust cup has a small gray tray that appears to be part of the cup, but is not. I made the same mistake also and almost broke the stupid thing trying to get it out. Simply push the lock to the left to unlock. Gently lift the dust cup and not the gray tray and the cup will slide out easily.
[IMG]http://i294.photobucket.com/albums/mm88/SteelNET13/vacuum2.jpg[/IMG]
[IMG]http://i294.photobucket.com/albums/mm88/SteelNET13/vacuum1.jpg[/IMG]
SOURCE: How do I to change the belt on an eureka altima 12?
the belt is on the bottom right (looking at it from the front). the Eureka website does have the manual for download, http://www.eureka.com/service/manuals/80244.pdf
With the vacuum flattened (straightened) out, turn it over and remove the back roller cover, (2 screws) once off, the roller should just pop out on the opposite side (opposite from the belt). Don't forget to turn the roller to center the belt once you have it on.
SOURCE: owners manual for 2981 eureka altima widetrack 12
http://www.eureka.com/service/manuals/74149.pdf this is a direct link to the PDF for the owners guide or you can call eureka customer service at 800-282-2886 and request a hard copy be sent to you
SOURCE: How do I change the belt on Eureka Altima 12 v
Here is
a link to the owners manual which has instructions and a link to the
belt you need.
Eureka Altima Owner's Guide
Eureka Altima Replacement Belts
