Video
SOURCE: i have jus brought a
I have just spoken with Acer Support, and where M5100's have dedicated graphics cards, this disables the onboard graphics including the HDMI.
The onl way to eabl the HDMI is to remove the dedicated graphics card, and revert to shared graphics which will enable HDMI. The problem with this, according to the support technician, is that it will slow the computer down considerably.
Why the hell do Acer do this? They must know this is an issue in the first place; absolute idiots.
SOURCE: Need correct SATA driver for a Acer Aspire M5100
All manuals and drivers for your M5100 here:
http://support.acer-euro.com/drivers/desktop/aspire_m5100.html
Best wishes.
SOURCE: acer aspire m5100 has a good power supply but
Try to check all the connection at the back of your pc,, try to unplug and open your cpu case,,, Maybe your Power cord is not properly installed .. find the power supply port in the motherboard and try to check it again if it is properly installed
SOURCE: How do I take apart case of Acer Aspire M5100 to
http://www.youtube.com/watch?v=kpiFF9ipmAo
please watch the above link - it will give you a generic idea of how to remove the case - the screws will be what holds the side in place. It is EASY - just don't over complicate it - - best of it
Gary
SOURCE: My acer aspire M5100 getting into shudown mode
Check the temperature of the CPU in Bios. It is probably higher than the Safe temperature and it gets into shut down mode to protect itself.
Open it, detach the cooler from the CPU and clean it, detach the CPU from the socket, clean the paste from the top, put a new one, clean the socket and put everything back. It should work perfectly.
If you need further assistance, just leave a comment.
Cheers
