Does the kick plate have to be removed from the bottom of the Kitchen Aid Superba KSR52206WH00 refrigerator?
Hi, the filter should be on the bottom kick plate and should have a cap of the same color as the kick plate.
Hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/roger_e8672cfe67bf61a1
SOURCE: Kitchen Aid Superba
To the person who hears a clicking sound you are correct, the compressor is trying to start but is not starting and that causes the overload to trip (click) wait a short time and it all happens again. Either the start relay is bad or the compressor is locked up. Less than 1 year old should be in warranty. If you want to try to check the relay you will need to unplug it from the side of the compressor. Once removed try to shake it and if you hear a rattle noise the relay is bad. To test the compressor you would need a test tool or be very experienced to perform accurate test.
supertechks
SOURCE: Kitchen Aid Ice maker Stopped working
I would suggest not buying a KitchenAid. I have the same problem with my ice maker. Have had nothing but problems with every KitchenAid product that I have ever owned. I will never purchase another KitchenAid product.
All of there appliances are second rate. That is "The KitchenAid Difference"
SOURCE: Refrigerator stopped cooling
I have the same problem on my GE model :
GTS18FBMERWW
It is a 18 cu ft, top freezer model.
If you get an idea please let me know.
TK
The ice maker has stopped working. The red led light blinks when the freezer door is opened. Any thoughts?
SOURCE: change filter?
filter is in kickplate under freezer door and it should turn counter clockwise then pull straight out then replace please rate me
