NorStar Compact Ics WithClid Trunk Mod (ntbu0686) Logo
A
Anonymous Posted on May 23, 2014
I cannot connect to an extention when trying to change a voicemail. it says connect to..i put my extention and it will not call it
Names are different on voicemail and extentions how do I change them on the voicemail
Hi Denise,
You should generally delete and re-add mailboxes when someone new takes over an extension. It allows the new person to customize the mailbox from scratch.
If all you want is to change the name, go:
Feature 983
Password: 1020000
Select Mbox
Enter the Mailbox number
Hit Next until you see the name, and then select change.
Enter in the new name, press next, and then hang up.
1helpful
We lost the voicemail password!
If you have an in-house administrator, they can log in and reset it. You might try 0000 and 1234 just in case, otherwise you will have to call whatever tech help you have and get them to reset it.
4helpful
Ringer/ Voicemail Bounceback
Well, this one is kinda tricky. If the receptionist knows there's no one there, they can use VoiceMail Transfer.
From the phone, the user can set CF Busy or CF Busy/No Answer with the following codes on the intercom:
Do Not Disturb *7101 / Cancel *7100
Call Forwarding2.gif (FWD)
– Both Calls *710
– Outside Calls *711
– Intercom Calls *712
2 (All calls) + phone no. + #/
3 (Busy) + phone no. + #/
4 (No Answer) + phone no. + #/
5 (Busy/No Answer) + phone no. + #/
7 (Follow Me) + your extension no./
8 (Follow Me Cancel) + your extension no.
So, if your voice mail is 500, you would dial *7105500# to set CF B/NA for intercom and outside calls.
The last piece of the puzzle is the timing. That's *713 (00-99). Start with 24 (4 rings) and go from there. If it hits the receptionist before the forward takes place, you probably have to adjust the recall timer for call transfer, a system program.
Carl
Voicemail change
I am sorry, but the best answer i have is to bring your phone into a verizon store and they will fix it for free.
2helpful
Norstar: Inactive Feature (981)
This generally happens from one of two things. Your voice mail system is connected to your phone system through a station port. If it loses connection it will not communicate with the phone system. Loose wire or connection can cause this. or it has just crashed and will need repair or replacement.
First thing you want to do is unplug the unit wait 15 minutes and plug it back in. wait 10 minutes Try feature 981 from a set that has voicemail. if nothing. hit feature 985 from a m7310 set or a m7324 set not a m7208. If it comes back with inactive fearture now your connection between the units is bad or the unit itself is bad. If it comes back with the voicemail intercom # and you cant get into any mailboxes it has lost all programming.Try this first.
2answers
Extention Recorded Name
Your name is in the Company Directory if you chose this option when you first set up your mailbox. To change it AFTER you set up your mailbox, press feature 9 8 1, enter your mailbox password, dial #, press ADMIN ( or 8 ), display should read
Mailbox admin
GREET PSWD QUIT
dial 1, at the tone record your name, press # to end recording, press # to accept, press RLS
It will look like you are re-recording your greeting but you are recording your " voice " name. Good Luck. ...Mike
1helpful
Company directory
Hi, if you are still having this problem you need to re-record the NAME on the mailbox as well as the greeting. On the Stratagy voicemail system, from the main menu after logging into your mailbox, choose option 3 then 6 to record your name. Hope this helps, ....Mitelmike
Changing the MAIN voicemail
you have to go into the administrators vm box.
press your vm btn or press intercom and dial 777.
at enter mbx prompt.
press 99#
password= 1234
press 9
follow the prompts.
hope this helps..
Can not receive calls from the outside
Do you own that number from the telco? Is it in your DID range? Did you put it in the right call routing table?
Adding voicemail to an existing extension
You need to build the mailbox in f983
Log 1020000
Mbox
Add or Change.
When you get to mailbox enter the extension # of the new telephone.
When you get to extension number-enter the same extension number.
Top NorStar Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NorStar Computer and Internet Expert? Answer questions, earn points and help others
