SOURCE: Amana SCD22JL
It sounds as though you have a refigeration problem if there is no cold on the coil, however you hav sad that you have changed the sensor which would bring in the fan when cold enough. As far as airflow I have been doing this a while on American cabinets and never really consider airflow as a primary failure. If the fan is running and the vents are clear that is normally enough, these fans are not high powered and the cabinets have a large volume. What you could try is leaving the door open whilst observing the coil and see if it frosts right through the coil without the fan running. If it does then it should pull down to temp. Hope this helps, unfortunately without seeing things its hard to give a definitive answer.
