Thank you so much!! I just now checked back after half a year (oops). Now that flashing 'change filter' sign is no longer blinking.
I appreciate it so much!!Thank you so much!! I just now checked back after half a year (oops). Now that flashing 'change filter' sign is no longer blinking.
You can't post conmments that contain an email address.
Turn off the unit Open the filter cover On the top right corner, there is a small hole Push a paper clip into this and the change filter light will stop blinking.
Resetting Filter Life:
After replacing your True HEPA Filter, place the Pre-Filter
back in and close the Front Panel. While the unit is on, hold
the Filter Reset Button for at least 5 seconds until you hear
the beep. After the beep, the Filter Replacement Indicator
will disappear. Your Winix True HEPA is now reset
<span style="font-weight: bold;">Airgle Air Purifier:</span><br />
<ol>
<li>Turn off and unplug the unit </li>
<li>Press the light button to the "on" position </li>
<li>Plug in the unit, and then release the button after the Filter-check starts</li>
<li>The system will automatically reset the Filter-Check Gauge in about 25 seconds</li>
<li>Once the procedure has completed resetting, please turn on the unit and press "Filter Check" button again.</li>
<li>This time, the system should report an accurate result.
</li></ol><span style="font-weight: bold;">Alive Air Purifier:</span><br />
<ol>
<li>Insert a straightened out paper clip into the reset hole, with the unit off, and push the Timer button.</li>
<li>You should hear a 2 beeps, signaling that the Reset was successful.</li></ol><span style="font-weight: bold;">Holmes Air Purifier:</span><br />
<ol>
<li>Units which have an indicator light must be
reset once the HEPA filter has been replaced. Reset indicator by inserting
a small object (such as a pin
or paperclip) into the hole marked reset.</li></ol><span style="font-weight: bold;">Honeywell Air Purifier:</span><br />
<ol>
<li>Reset the filter indicator by pressing and holding the "Filter Monitor" button until the indicator light shuts off.</li></ol>or<br />
<ol>
<li>With the unit powered on, press and hold the appropriate filter<br />indicator button down for approximately 10 seconds until the<br />light turns off.</li></ol><span style="font-weight: bold;">Hunter Air Purifier:</span><br />
<ol>
<li>Change the filter and/or pre-filter.</li>
<li>Now, you must choose which counter you want to reset. Press and hold the filter reset key (approximately three seconds) until the prefilter indicator flashes. Press and release the reset key again to alternate between the two indicators. The counter that will be reset is designated by the flashing indicator. For Models 36394 and 36395: Use the tip of a pen or pencil to press the key.</li>
<li>Once you have the correct indicator flashing, press and hold the reset key for three seconds to reset that counter to zero hours. The indicator will stop flashing when it has been reset. If needed, repeat these steps to reset the other counter.</li></ol><span style="font-weight: bold;">IQAir Air Purifier:</span><br />
<ol>
<li>To reach the Filter Life Reset function from the main display window, press the Menu key seven times.</li>
<li>Press and hold the Enter key until the flashing cursor appears. Release the Enter key. The first filter selection to appear is the Pre-Filter.</li>
<li>Press the Up Arrow key to select the filter that has been replaced. The Filter Life LED for the appropriate filter is now flashing red.</li>
<li>Press the Enter key to confirm that the selected filter has been replaced. The filter life LED for the appropriate filter is now flashing red.</li>
<li>Press the Enter key one more time to confirm the filter change or to exit without resetting the filter life, press the Menu key (M=Menu).</li>
<li>Upon successful reset of the filter life, the new remaining filter life (taking the currently selected fan speed into account) will be displayed, and the filter LED light on the control panel will change from red to green.</li></ol><span style="font-weight: bold;">Kenmore Air Purifier:</span><br />
<ol>
<li>Press the FUNCTION and OFF TIMER buttons at the same time for five
seconds. The CHANGE FILTER INDICATOR will flash five times and turn off
</li></ol>
*Plug in air cleaner and press POWER button until short “beep” sounds. . Press the RESET FILTER button by gently inserting a paperclip into the RESET FILTER hole on the control panel. The light will flash 5 times before a “beep” sounds to indicate the filter has been reset.
Make sure that the new filters you installed are undamaged and correctly seated in it's assembly. When resetting the unit, unit must be powered on then press and hold the appropriate filter indicator button for approximately 10 seconds until the light turns off. If nothings happens, unplugged the unit from the power for about a minute and then try to reset the unit. If all else fails, I would suggest to contact Honeywell for more assistance.
You can purchase a wide variety of high quality Honeywell replacement parts for your Honeywell Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
It looks like you may need to change your filters. It is advisable to change filters every 3-6 months for optimal use. When replacing your filters, make sure that the unit is turned off and unplugged from the power. Once filters are replaced, turn on your unit then press and hold the filter check indicator button for 3 seconds. The indicator light will blink 3 times and turn off, and reset the filter change timer.
You can purchase a wide variety of high quality Holmes replacement parts for your Holmes Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Filter Replacement Filter Replacement Indicator: Your Defender® is equipped with a Filter Replacement Indicator located on the front panel. Anytime this red indicator flashes, it is recommended that you call your authorized FILTERQUEEN® Distributor to order a replacement filter. Anytime this red indicator stops flashing and remains solidly illuminated, it is recommended that you change your filter. To receive full benefit from your Defender® and to extend your warranty, it is strongly recommended that you follow the filter replacement schedule suggested above. Under higher pollution levels, your filters will need to be replaced more frequently. The Filter Replacement Indicator is operated by filter time in use and is controlled by an onboard timer. After 11 months of time in use of your Medi-Filter® Cartridge, the Filter Replacement Indicator will begin to flash. It will continue to flash until the you reach 12 months of time in use, at which time the Filter Replacement Indicator will stop flashing and remain solidly illuminated. After replacement of your Medi-Filter® Cartridge, you must reset the Filter Replacement Indicator's timer. When the timer has been properly reset, the Filter Replacement Indicator will turn off. Resetting the Filter Replacement Indicator Timer: After replacement of your Medi-Filter® Cartridge per the instructions found on page 7, the Filter Replacement Indicator's timer can be reset by performing the following sequence of steps: 1Plug unit into outlet. 2Press power On/Off switch to the On ("I") position. 3Allow unit to start running at low speed. 4PRESS and HOLD both the Up and Down arrow buttons until the Filter Replacement Indicator starts to blink. 5 Release both the Up and Down arrow buttons. 6 While the Filter Replacement Indicator is still flashing*, again PRESS and HOLD both the Up and Down arrow buttons until the Filter Replacement Indicator turns off. If the steps above have been performed properly, the Filter Replacement Indicator will turn off and not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again. *Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time. The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above. Note: Under higher pollution levels, your filters will need to be replaced more frequently. Note: To order replacement filters, call your authorized FILTERQUEEN® Distributor, or call 1-440-846-7800 for the Distributor nearest you.
1. Plug unit into outlet.
2. Press power ON/OFF switch to the ON position.
3. Allow unit to start running at low speed.
4. PRESS and HOLD both the UP and DOWN arrow buttons until the FILTER REPLACEMENT INDICATOR starts to blink.
5. Release both the UP and DOWN arrow buttons.
6. While the FILTER REPLACEMENT INDICATOR is still flashing, again PRESS and HOLD both the UP and DOWN arrow buttons untile the FILTER REPLACEMENT INDICATOR turns off.
If the steps above have been performed properly, the Filter Replacement Indicator will turn offand not flash again for 11 months. If the Filter Replacement Indicator remains on, repeat the steps again.
*Note that in step 6 above, the Filter Replacement Indicator MUST still be flashing when the buttons are pressed the second time.The Filter Replacement Indicator will continue to flash for approximately 3 seconds after the buttons are released as required in step 5 above.
So after you have replaced the V5 Cell Filter in the IQ Air, here are the steps you'll need to follow in order to reset the filter indicators:
At the main menu on the control panel, push the menu button 7 times until you get to the screen that says Replace Filter.
At the Replace Filter screen, press and hold the Enter Key until the cursor appears, and is flashing.
Press the UP arrow button on the keypad until you get to the V5 Cell Filter.
At the V5 Cell Filter screen press the Enter Key to confirm your filter reset selection. This will turn the corresponding filter LED to a flashing red light. IQAir requires that your reconfirm the filter selection to prevent inadvertently resetting the wrong filter. If you chose the wrong filter, press the menu key after pressing the enter the first time to disregard the filter change command.
To confirm the filter reset selection, press enter a second time, which will reset the filter life, and reset the filter hours.
You can repeat these instructions for the other two filters on your machine when it's time. Here's a link to the product manual for your IQ Air Health Pro Plus which will give you the same instructions, as well as other maintenance instructions.
I hope that this information was helpful to you. If you were able to reset your filter, please be kind and rate the repair as helpful by clicking the thumbs up icons in the top of my repair. This is what really keeps Fixya experts continue leaving free repair solutions. Thank you very much,
When the red light is blinking, press and hold both up and down arrows until the red light blinks RAPIDLY, release both for a second or two, and press and hold both again until it stops blinking. It cured my problem.
