I need to print fax confirmation sheets with each fax I send. How do I set my printer/fax to do this. I do not see anything in the setup menu or Canon website.
Thanks
Navigate to the Settings on the Printer itself, Under Settings there would be a column which would say Fax settings, Under that you would see an option to Turn it Off!!!!! Good Luck!!!!!
HP
LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX
Confirmation Report
Description
By default, a Fax Confirmation report (Fax Call Report) will only print
when a fax error occurs. However, this option can be changed using the
printer control panel.
Press the right arrow until Reports appears in the display, press the checkmark.
Press the right arrow until Fax Call Report appears in the display, press the checkmark.
Press the right arrow until Print Report appears in the display, press the checkmark.
Right arrow to the option of choice, press the checkmark to save the change.
FAX call report options
Send Fax Only - a confirmation sheet will only print when a fax is sent
Never - no fax confirmation sheets
Every Error - default setting
Send Error - a fax confirmation prints when the fax transmission encounters an error
Every Fax - a fax confirmation sheet will print for incoming
You can use the reports button or menu button to reports, and print out the user settings list. It shows where the settings are, and what they're set on. In fax setup you can select frequency of report printing, but the Brother machines always give a printout if a fax fails.
Press the Setup button (it might be the sign of a monkey range)
Press the Down arrow ( ) to highlight Print Report , then press OK .
Press the Down arrow ( ) to highlight Fax Confirmation , then press OK .
Press the Down arrow ( ) to select one of the following options in the table below, then press OK
On Fax Send
Prints a fax confirmation report for every fax you send.
On Fax Receive
Prints a fax confirmation report for every fax you receive.
Send and Receive
Prints a fax confirmation report for every fax you send and receive.
Off
Does not print a fax confirmation report when you send and receive faxes successfully. This is the default setting.
Select the one you would like to choose ;
For further help click on the following Link:
Keep pressing menu button on machine until you see until you see "Reports"in screen then press right arrow and scroll through to ""send report then press enter. The report of all recent faxes sent will print from the machine.
Good Luck
By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
Every Fax - a fax confirmation sheet will print for incoming and outgoing faxes
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it. Thanks, Joe
document.tlSearch.tx.value=unescape("")
HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report
Description
Description
