Freezers Logo
Ken Krueger Posted on May 23, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a kenmore 253.1654 chest freezer that blew my home breaker, after the breaker was reset it omitted a hot electrical smell, the unit was unplugged an left stand for an hour or so, now plugged in and seems to be fine. Any thoughts?
william rodriguez
Level 3:
  • Master 958 Answers
  • Posted on May 24, 2014
william rodriguez
Master
Level 3:
Answers
958
Questions
Helped
169882
Points
2511
THE COMPRESSOR COULD HAVE HUNG UP CAUSING IT TO KICK THE BREAKER
5 Related Answers
bobotfel
Felizardo Erilla
  • 241 Answers
  • Posted on Dec 28, 2007
SOURCE: kenmore chest freezer power problem
Try to unplug the the unit power supply to reset the error. But if the error persist you have to call for a qualified technician,
Anonymous
  • 288 Answers
  • Posted on Feb 19, 2008
SOURCE: Kenmore 23.1 cf Chest Freezer not cooling below 14F
Make sure everything is working, I.E. compressor, fans. Now I need to know if the freezer shuts off at 14 degrees, or does it continue to run without making temp. If it shuts off, then the first place to look is the thermostat. It may be out of calibration. If it continues to run, then the solution may be as simple as cleaning the condenser coil. or the defrost has malfunctioned somehow. Defrost probleams will cause excess ice on the inside coil. You may need to remove the panels to see how much ice is on it. It sounds like the compressor is good, as it is pretty cold. Just not cold enough. A deep freeze should be at least 0.
Terry Engel
  • 176 Answers
  • Posted on Feb 01, 2009
SOURCE: Used chest freezer not cooling
Slobberlips,
One of two situations has occured with your used freezer:
1: The unit freon needs to be recharged, this happens when you develope a leak in the freon coils, or the unit is old enough that the freon has reached it's usable potential.
2: The compressor may seem to run fine, but in fact, has an internal problem.
My suggestion, return the unit if you can, and walk the isles of your local Menards, Sears, or any other local vendor in your area, and see how much prices have declined for the chest freezer.
The initial investment for a new freezer will offset any problems you might have with any other used unit, and the warranty is always a plus if you do have problems with the new unit.
Hope this helps you out.
Anonymous
  • 585 Answers
  • Posted on Jun 28, 2009
SOURCE: Hot exerior walls in a brand new Kenmore 28042 upright freezer
There should not be a fire hazard but you should be concerned that the freezer could break down if it is not allowed to vent the heat it produces. The freezer is not intended nor designed to be enclosed The manual must indicate specifications for minimum clearances for rear, top and sides, and may even be indicated on the big yellow sticker on the inside of the door. The clearances must be respected or again, the unit will fail, and the warranty may be voided in such cases.
Anonymous
  • 162 Answers
  • Posted on Jul 26, 2009
SOURCE: Outside of chest freezer gets hot
it is normal for outside to get hot. that is where the condensor coils are located. if unit is working don't worry.
My frezer is getting hot on the sides-why?
Its normal. The manufacturers got smart and put the condenser in the outside freezer walls. A lot of home refrigerators also have the same hot walls. Hope this helps good luck.
1helpful
Chest Freezer Stopped Working 14 years old
The first thing you want to ensure is that power is actually getting into the unit. i suggest that you do that by plugging a night light into the outlet and verify the presence or power. If no power, check your breakers. If power is present note that A chest freezer has only two working parts; the start relay that help the compressor start and a compressor. If you are getting clicking sound, your start relay may be out (inexpensive if you can buy it and install it yourself) or a bad compressor. if you need to call a tech for the repair, you may be able to purchase a new chest freezer that now consume HALF the power and for less than cost of repair.
5helpful
2answers
Can a chest freezer be used in an unheated garage where the temeprature falls below freezing for an extended period? The garage is insulated so it doesn't get as cold as outdoors but it does drop below...
why not then when its down to zero shut the unit off and open the lid and free freezing...no electricity required....remember pop machines sit out in all types of weather
1helpful
My chest freezer shut off (the outside light was
Try to plug somthing that you know it works ,in that outlet ,and if it doesn't work or goes on and off , the problem is in the outlet, but if works without trouble ,the problem could be in the freezer plug , the cord or the cord conections to the freezer.
The front surface of the chest freezer is pretty hot.
the condenser lines are between the walls of the frzr and if it has a fan to cool the compressor down and it is stalled is the reason the walls are so hot and no it will not cool down over time if new is a flaw in making of this unit take it back or if older only the side should be getting warm not hot then if older be cautious of this no repair can be done on these type of unit they are between foam filled walls....
3helpful
Hi, can you put your hands on front of freezer, and check from 1 to 5 without getting burn? how long can you keep your hands on front of freezer? check from 1 to 20 and let me know, normally there's a condensate line, or part of condenser lines that passes through freezer body , purpose of those condensate line is to prevent your door gasket from freezing , especially during winter. It's normal for front of freezer to be warmed, on hot days it will be a little hotter, you said "very hot" makes me wonder how hot it is, put your hands on front of freezer, use number method and let me know, but it's normal. good luck.
Chemical odor in freezer
can you verify the odor. Does the odor smell like burnt wire insulation or of that of burnt meat?
Freezer/kenmore
the settings usually are:
off - on - superfreeze. you just want "on"
2answers
Kenmore chest freezer power problem
Top Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Freezer Expert? Answer questions, earn points and help others
