Plugged my tablet into a "Sharper Image" USB wall plate charger and as a result, it no longer charges up using any combination of charger cords or USB plug adapters. Nothing shows up on the screen.
SOURCE: My Archos 101 tablet's full sized USB port doesn't
This seems to be a widespread problem with the Archos 101 tablet. There have been 2 firmware updates since the problem was first reported, and neither seems to have fixed the issue for anybody, which strongly suggests that it is a hardware issue, in which case you'll need to do an RMA. I recommend contacting the retailer you purchased through so you can get a replacement unit or a refund.
SOURCE: The battery completely drained and now I have it
Well the screen will Turn on but like mine it drained and I hadn't been on it for a while and then I plugged it in and it didn't turn on but I Just left it and then it fired to Life !! I hope this Helped x
SOURCE: Brand new archos arnova 10 tablet. It is stuck on
To hard reset a tablet, hold the power button down until it shuts off then press it to turn back on. Should take about 5 - 10 seconds for the device to power off.
