"HDD mount" means it has an internal hard drive (HDD, or hard disk drive), and the copier has failed to "mount" (place in operation) that disk drive. That error means that the internal hard drive has failed and needs to be replaced. It will very likely need to be a special proprietary hard drive, preloaded with some sort of operating system for the copier, and you'll need to get it from a dealer.
Developer must be replaced by a technician. Old developer has to removed and new installed. Then there are software adjustments and counters to be reset as well.
clear very well the paper path especially if there is bridge who trasfer the paper to the finisher and check the sensor inside it or check if there is any load at the main motor
There
is a sensor just behind the waste toner box that sends beam through the
water toner box to see if reaches the other side. If it does not, then
the sensor thinks that the box is full. So you need to clean the waste
toner box with some liquid cleaner so that it looks white from outside.
Once the box is dry, try again. This should work now. Otherwise, there is problem with the sensor.
It depends what the copier is doing, is it giving error codes one of the main faults on the copier is it dumps colour toner and that causes problems need more info
