NorStar T7208 Corded Phone Logo
Posted on Jun 24, 2009
Mailbox locked - Contact Administrator
Who do I contact to be able to unlock it. When I returned from holidays this was how it was.
There are messages and I need to do this.
Thank you so much
A
Anonymous
You need to log in as the admin and reset the password in mailboxes.
How do I set up a voice mail with a Nortel M3904?
This is dependent on you being able to access your voicemail mailbox (a mailbox has been setup for you by the administrator and you know the codes to login to your mailbox). Go to your voicemail which should be:
  1. press the message key.
  2. Enter your mailbox number, then press #
  3. Enter your password, then press #. (if you don't know this then you will have to contact the administrator for the telephone system)
When logged into this:
  1. press 82.
  2. Press 1 for external greeting, 2 for internal greeting, 3 for temporary greeting, or 9 for Personal Verification (spoken name)
  3. Press 5 to record then wait for tone.
  4. Press # to end recording
  5. Press 2 to listen to the greeting
  6. Press 76 then 5 to delete the greeting and re-record it.
  7. Press 4 to return to your messages.
Nortel phone - VM box locked contact admin - tried solutions & no luck
Hi Lyndsay,
Have you tried feature 985, and then press 9, and enter the passed resetsmppwd? That should reset the login on feature 983 to 1020000 for three digit extensions, or 102000 for two digit extensions. Once you get into there, you can reset the mailbox password for the general delivery mailbox. Depending on your system, even though the general delivery mailbox might be on extension 363, the mailbox number is likely to be 100.
24helpful
2answers
I am locked out of my admin mailbox on my nortel nt8b26aabl phone, when i use feature 983 and then password 102000, it says invalid password.???
to reset the administrator pasword enter feature 985 press 9, at the password prompt enter 73738767793 (resetsmpwsd) and press ok or #,press yes to reset password. password should be defaulted to 0000. then try Feature 983. if your system has 2 digit intercom #s your password is 120000 if your system has 3 digit intercom #s your password is 1020000.
How to change time stamp on messages to reflect correct time. Time on phone system is correct
Dial into the voicemail and enter *#
followed by the System Administrator2.gif Mailbox number:
[#]+[0] = two-digit mailbox system
[#]+[00] = three-digit mailbox system
[#]+[000] = four-digit mailbox system
When requested, enter the System Administrator password. Default = [9]+[#]+[56].
Press [4] to set date and time
either enter:
[1] to review data - the current date and time settings in the Voice Mail are announced,
then you are returned to the Administrator Options Menu.
-or-
[2] to change data - after the first prompt, enter the time in four-digit military time format
e.g., 0930 for 9:30 a.m. or 1830 for 6:30 p.m. After the second prompt, enter the date as a
six-digit number in MMDDYY format. You are then returned to the prompt that asks if you
want to review data, change data, or exit.
4helpful
I have the same problem: mailbox locked
How to Change a Mailbox Password (Administrator Only) 1. To access the voice mail system press "Feature".
2. Press "983".
3. When you see "Log:" enter "120000" for 2 digit extension numbers, enter "1020000" for 3 digit extension numbers.
4. Press "OK".
5. Press "MBOX".
6. Press "CHNG".
7. Enter the mailbox number (same as extension number) you wish to reset.
8. Press "Reset" softkey.
9. Press "Rls" to exit (orange button to the right of the number buttons).
The Default password is "0000".
2helpful
Mbox Locked - Feature 981
Feature 985 is used for resetting the administrator password.To reset a subscriber mailbox press feature 983, enter in log (default 1020000), on the 3 soft keys bolow the the screen press mbox,chng, enter extension number of the locked mailbox, press reset at the reset password prompt.press rls key
2answers
My nortel voicemail is locked
What password is no longer valid? The admin, the operator, the installer?
What are you pressing to log in?
5helpful
I have a similar problem.
Press feature 985
Extension of vociemail is displayed. Dial 9
PSWD: RESETSMPSWD (73738767793)
Reset PSWD? Press YES
Login will be changed to default (1020000 for 3 digit EXT's or 120000 for 2 digit)
Log #
If you are not the System Administrator/Coordinator, your phone doe not have this privilege.
Please use the Feature 981 enter your password. You really should ask your Administrator to delete your mailbox and re-add it.
T7208 nortel network general voicemail locked
Generally, you dial feature 981 to get in, then extension number and password. If you have no new messages it will say that, then give you the option to review old messages. To delete a message you press 76. If that doesn't work, login to your mailbox, press 8* then 6 to get to "go to message" then press the message number and #. If you have an on-site administrator, they can delete your mailbox as well, otherwise you will have to call your tech help service and have them erase it remotely.
Top NorStar Lands Phones Experts
Paul Bade
Daniel Blask
Daniel Blask
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
