Dell Inspiron 1501 Notebook Logo
A
Anonymous Posted on May 22, 2014
Disk read error preventing startup?
Running Windows 7
Neal Schwartz
Level 1:
Habit-Forming:
New Friend:
  • Contributor 24 Answers
  • Posted on Mar 08, 2016
Neal Schwartz
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
24
Questions
0
Helped
4959
Points
62
Remove hard drive and connect with USB hard drive kit and retrieve data now. Then reinstall Windows. If drive is bad during setup, windows will let you know
Rusty Dixon
Level 1:
New Friend:
  • Contributor 31 Answers
  • Posted on Mar 06, 2016
Rusty Dixon
Contributor
Level 1:
New Friend:
Answers
31
Questions
0
Helped
3807
Points
72
Your hard drive might be damaged. Each time you attempt power it on you risk further damage. If you have valuable information on it you should contact a shop who specializes in data recovery.
2 Related Answers
Anonymous
  • Posted on Dec 18, 2009
SOURCE: My Samsung n130 has crashed and won't recover.
hell can some one help me get dell latitude D600 laptop driver for free download? i just need the site for that ....
puertobori
  • 7733 Answers
  • Posted on Apr 19, 2012
SOURCE: Srartup Repair Not working?
Try:Turn the machine off, turn it back on and IMMEDIATELY press two keys: CTRL +F6. If you hear a distress series of beeps (around 5/sec) keep pressing for about 1 min. After that release F6 but keep pressing Ctrl for a while.At this point the MS Windows Boot Console should appear and offer you choices. Choose Boot in Safe Mode With Internet.
Now, that combination Ctrl+F6 is maker specific. It worked for my DELL
towers. Other manufacturers reportedly have other "secret" codes.
You may try Alt, Del, PgUp, PgDn instead of Ctrl. Also F6 is not cast in
concrete. You may try other function keys. Some machine may require only one key to be pressed.Every machine MUST have a code like this. It took me about 10 min to find.1. Remove all floppy disks, CDs, and DVDs from your computer, and then restart your computer.
Click the Start button, click the arrow next to the Lock button, and then click Restart.2. Do one of the following:• If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you will need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
• If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to repair, and then press and hold F8.3. On the Advanced Boot Options screen, use the arrow keys to highlight Repair your computer, and then press ENTER. (If Repair your computer is not listed as an option, then your computer does not include System Recovery Option as a preinstalled recovery option.)4. Select a keyboard layout, and then click next.5. Select a user name and enter the password, and then click OK.6. On the System Recovery Options menu, click system restore and restore the computer to the date it was working fine.
1helpful
Dell-n5050 laptop; windows failed to start; code-0xc000000e; boot failed because required device is inaccessible. I have Dell OS media stick. and is there a free fix for this problem?
That code is a Windows boot error. I'm not sure what you can do with the Dell OS media stick but the traditional solution with a regular hard disk is to take a Windows 7 OS disk, boot with it, and run startup repair. Here's a link to Startup Repair: Startup Repair Microsoft Windows
tip
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy...
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy Tips
If you fail to boot the operating system, you can:
#1. Use Windows startup Disk to fix Windows 7 startup problem
If the failure of booting is result from the errors or the damaged files of starting system, a start up disk will help to solve this problem with ease.
#2. Use last know Good Configuration to fix Windows 7 startup problem
It is also a common method to enter the operating system. To use last know Good Configuration you can press F8 when you reboot the system. Then select "Last know Good Configuration" on the Advanced Boot Options screen to enter this mode.
#3. Use System Restore option in safe mode to fix Windows 7 startup problem
Enter the safe mode as the step in to last know Good Configuration in method #2. Choose System Restore option in System Tool in start menu.
If you find the startup process of Windows 7 very slow, we suggest that you should:
#1. Remove redundant programs in your booting items as many as possible. After finishing this action, the speed of startup can be improved by no less than 40%.
#2. Delete short cuts on desktop. The more icons on the desktop, the longer it takes to restart Windows 7. To fix Windows 7 startup problem, you should clear up the unnecessary short cuts on your computer desktop.
#3. Optimize registry regularly with proper registry maintenance tool. Registry error is the main reason that slows down the rebooting speed. You had better do registry cleanup timely to speed up Windows 7 start up process.
on Jan 12, 2010 • Computers & Internet
1helpful
2answers
Asus 1225b slow boot win 7
Most likely Yes. Her are some tips: http://www.techrepublic.com/blog/10things/10-ways-to-speed-up-windows-7/3332 Use freeware CCLEANER: http://www.filehippo.com/download_ccleaner/ This freeware program has many useful tools. The cleaner will remove junk and free up disk space. In the TOOLS section, STARTUP section, disable ALL unnecessary startup programs. Remember, almost every program you install wants to startup at boot, which, in most cases isn't necessary. You can configure what you need at start, use CCLEANER, TOOLS, STARTUP.
Toshiba laptop restarting
The loop on your Toshiba Satellite laptop refers to the computer not booting properly.
During the loop, the computer will try to boot the Windows operating system and keep restarting over and over again.
This is not a hardware issue with your Toshiba Satellite A106.
The issue resides in the startup files on your computer's hard drive.
You can fix this by running a repair tool that comes with your Windows operating system.
This repair tool will fix your startup disk and allow you to get your computer back up and running.
Insert your Windows 7 installation disc into your computer's optical drive.
Start your computer and wait for it to boot from the install disc.
Choose your language from the menu and then click the "Next" button.
Click "Repair your computer" from the menu.
Choose the operating system you are using and then click the "Next" button.
Click on the "Disable Automatic Restart On System Failure" button to disable the startup loop.
Click the "Startup Repair" tool from the menu and wait for the computer to fix your startup disk.
Wait for the computer to finish repairing your startup disk and then allow it to restart automatically.
Wait for the computer to boot correctly to your login screen.
Hope this helps
How to Create a Windows 7 System Repair Disc:
http://www.sevenforums.com/tutorials/2083-system-repair-disc-create.html
"This will show you how to create a Windows 7 system repair disc to use to boot to the system recovery options if you don't have a Windows installation disc, can't find your
Windows installation disc, or can't access the recovery options provided by your computer manufacturer."
or
If you do not have access to either disc: Windows 7 - Repair Disc download
http://neosmart.net/blog/2009/windows-7-system-repair-discs/
I turned off my computer all of a sudden before it saved settings.the next time i turned on my computer, all icons were not there and windows installer is not working. micro soft office is also not...
Maybe you can try this.....IF you have Windows 7 Operating System...AND If you have previously made an "External Start-up /Repair Disk" for your PC....While the PC is running, insert it into your external CD-ROM disk drive, then shut down/restart your PC. I have had to use this external Startup/Repair Disk several times with my Windows 7 system when it had problems...or the PC just would not boot up....and it corrected my Win7 operating system start-up system / software problems successfully. Hope fully your PC Bios "setup" is setup to go look at the external drive during startup mode to see if their is a "boot" disk in there. Your PC Manual should tell you how to change the PC Bios system Setup so that when you start it up, the PC will look at the external CD-ROM drive for the presence of a boot-up start program like the Windows External Start/Repair disk.
Hope this helps. Gary
This Startup/Repair Disk is created by the PC User after early operatation the PC operating system... based on instruction manual from the PC maker. If you have Windows 7 and did NOT make this external startup/repair CD-ROM disk...I recommend you do that ASAP...and try it out.
Windows canot find windows system32 drivers prgds exe
Are you getting this error message on startup/login? Does it prevent you from logging in? If so then try starting in Safe mode. See http://windows.microsoft.com/en-US/windows7/Start-your-computer-in-safe-mode for instruction on doing this in Windows 7.
What version of WIndows are you running?
3answers
My computer is running slow.
Many factors may cause your Windows 7 running slow: lack of memory, useless programs, wrong startup settings, junk files, registry redundancies, viruses or spyware and more.
If you computer is running slow or starting up slow, you may visit this article to learn more.
1helpful
2answers
Wifes brand new dell inspiron suddenly running very slowly after only a month and a half.
Scan Pc for virus and spywares, read my tips on face book on how to optmized your pc. .........metropcstech
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
