Question about Kohler 12 kW Emergency Power System - 12RES-L
QUE SIGNIFICA EL CODIGO UU EN KOHLER 12RES - Kohler 12 kW Emergency Power System - 12RES-L
SOURCE:
  • 1810 Answers
SOURCE: UU undervoltage kohler 20kva
call koler but ui think is meant high heat as in the thermal circut is shuting you down or low oil
could be a couple of things best bet call kohler
Posted on Aug 06, 2009
consaka
  • 661 Answers
SOURCE: Kohler Model 12RES LP gas generator starts
Sounds like a short in one of the windings to me. Can you verify that the engine rpm is not exceeding specs? If you can modify the engine speed Id say slow it down and see what the voltage read is.
Posted on Jul 22, 2010
SOURCE: I have Kohler 12Res generator,sometimes
If it has a couple hundred hours or more, try cleaning the slips rings on the back of the rotor shaft. They should be very shiny and not black or polished looking.
Posted on Sep 06, 2011
wglisk
SOURCE: Can some one tell me what oil and air filter to
Kohler Model 12RES generator manual calls for use of synthetic oil (Mobil 1 or equivalent) as follows: If temperature is normally above 0 degrees F, use 10W30. If temp. is normally below 32 degrees F, use 5W20 or 5W30. NAPA Auto Parts recommends their #1056 oil filter for the 12RES.
Posted on Sep 06, 2012
  • 12 Answers
SOURCE: I have a Kohler 12RES, 12.5kw genset. Less than a
Replace mag pick up. Cranking voltage on the MPU should be at least 2 volts AC. Normally MPU goes out.
Posted on Nov 29, 2012
Que significa el codigo de error EE? en el display .
posible termistor en cortocircuito en el evaporador refrigerador o el cableado del termistor. el corto es m?s que probable que en el conector del termistor. el trabajo debe ser realizado por un profesional capacitado.
Feb 28, 2015 | Sub-Zero 632 / S
Quiero liberar mi movil
Quiso decir que desea c?digo de desbloqueo de la red?
S? significa, que usted puede conseguir el c?digo de desbloqueo de su proveedor de servicio o bien tratar de comprar un c?digo de desbloqueo de uno cualquiera de los proveedor de servicio de desbloqueo en l?nea como SuperUnlockCodes.com Aqu? se puede desbloquear el tel?fono a bajo costo.
Dec 23, 2014 | Nokia C202
Code p1682 driver 5 line 2
Mi chevy equinox 2007 esta con un grave problema en el encendido, cuando arranca, lo hace deficientemente y la pantalla dice que hay perdida de potencia, conecte un OBD II y me da el codigo P1682 driver 5 line 2...quisiera saber que significa y como puedo resolverlo,ya que es muy desagradable lo que estoy pasando
Apr 11, 2014 | 2007 Chevrolet Equinox LS New Cars
Que significa SRS en el panel de mi mitsubishi mirage 1995
Hola:
EL codigo SRS se refiere al sistema de seguridad del vehiculo (Air Bag System), y aparece cuando se presenta algun codigo de falla en el mismo.
La presencia de un codigo de este tipo no sera eliminada con solo desconectar la bateria durante algunos minutos; necesariamente tendra que llevar el vehiculo a su representante o algun taller que cuente con lector de codigos (scanner) para determinar exactamente que codigo de falla se ha presentado, Solamente con este codigo podriamos ofrecerle mayores detalles.
Suerte.
Jul 10, 2012 | 1995 Mitsubishi Mirage
Quiero saber que significa el codigo P 0172, tengo problemas con las revoluciones del motor, se me apaga el motor cuando esta en baja, lo puse en la computadora y primero me *** P 0496, ya esa piesa la...
B?sicamente esto significa que un sensor de ox?geno en el banco 1 detecta una condici?n de rica (muy poco ox?geno en los gases de escape). En V6/V8/V10 motores, el Banco 1 es la parte del motor que tiene el cilindro # 1.
Nota: Este DTC es muy similar al P0175 , y, de hecho, su veh?culo puede mostrar dos c?digos al mismo tiempo.
Los s?ntomas: No m?s que probable que observa cualquier problemas de manejo, aunque puede haber s?ntomas como un fallo de encendido.
Un c?digo P0172 puede significar que uno o m?s de los siguientes ha ocurrido:
El MAF (flujo de masa de aire) del sensor est? sucio o defectuoso. Nota: El uso de filtros "aceitado" el aire puede causar que el MAF se ensucie si el filtro est? m?s aceitada. Tambi?n hay un problema con algunos veh?culos, donde los sensores MAF fuga del material de silicona para macetas utiliza para proteger los circuitos.
No puede haber una fuga de vac?o.
Podr?a haber una presi?n de combustible o un problema de entrega
Las posibles soluciones son:
Inspeccione todas las mangueras de vac?o y PCV, reemplazar si es necesario
Cleanthe MAF sensor. Consulte el manual de servicio para su ubicaci?n si necesita ayuda. Me parece que lo mejor es sacarlo y rociarlo con un limpiador de electr?nica o limpiador de frenos. Aseg?rese de que est? cuidado de no da?ar el sensor de MAF, y aseg?rese de que est? seco antes de volver a instalar
Inspeccione las tuber?as de combustible para las grietas, fugas o pellizcos
Revise la presi?n de combustible en la l?nea de combustible
Revise los inyectores de combustible, que puede estar sucio. El uso de combustibles m?s limpios de inyecci?n o hacer que una limpieza profesional / reemplazado.
Compruebe si hay una fuga de escape antes del sensor de ox?geno primero (esto es poco probable que la causa del problema, pero es posible)
Detalles adicionales a traves de este enlace: ODB Fault Codes - Codigos de Falla
Suerte.
Sep 26, 2011 | 2005 Chevrolet Colorado
Tengo un problema con el carro esta prendida la luz del motorsito esto que significa
Debemos asumir que esta refiriendose a la luz testigo del trablero que indica "Check Engine"...
Cuando esto ocurre, al computador del vehiculo le esta advirtiendo del mal funcionamiento o una se?al erronea que esta enviando algun sensor. Lo primero que hay que hacer es "escanear" la computadora con un Lector de Codigos, asi podremos conocer el "numero" exacto de este codigo, de acuerdo con esto, podremos iniciar tareas de diagnostico y reparacion.
Mantengase en contacto y envienos el codigo cuando lo haya determinado.
Sep 16, 2011 | 2006 Chevrolet Cobalt
_CUAL ES EL CODIGO DE PANTECH215 LIBERAR
El c?digo de desbloqueo de red lo que significa que el c?digo llegar desde el sitio en l?nea, de seguridad El c?digo de desbloqueo significa obtener el c?digo maestro de reinicio del proveedor de servicio y restablecerlo ... El c?digo de desbloqueo gratis no es posible obtener de los tel?fonos antiguos, como Nokia M?viles DCT, pero este tel?fono PDA usted tiene que pagar para el c?digo de desbloqueo, puede obtener el c?digo de aqu? Wickedunlock y desbloquearlo ...
Jul 24, 2011 | Pantech VZW PN 215 Cellular Phone
APARECE EL CODIGO C6020 Y NO PERMITE SACAR COPIAS
El codigo C6020 significa que hubo sobrecalentamiento en el Fuser. Si Ud. es tecnico en copiadoras, cheque la resistencia del THMS, ien caso de ser 0 ohms, reemplace. De otro modo, puede que la fuente de poder esté dañada. despues de hacer reemplazo de piezas, resetee la copiadora con el codigo U163.
En caso de no tener idea de que estoy hablando, le recomiendo solicitar servicio tecnico para la computadora ya que es un problema serio en el equipo.
Dec 07, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
Desbloqueo del codigo m2 en konica minolta bizhub 163
Este código significa que la vida las partes de su desarrollo + unidad de imagen se ha caducado. Ahora es el momento de reemplazar las partes.
May 18, 2010 | Konica Minolta bizhub 161f All-In-One...
No est? funcionando
El codigo H98 indica que puede haber un magnetron defectuoso, tambien que puede haber una fuente de alimentacion defectuosa o puede ser que exista un falso contacto en el connector CN702. Han habido reportes que la fuente de voltaje ha salido con poca vida y fallan a menudo.
Si habres este aparato ten cuidado con el alto voltaje que existe en un condensador de alto voltage.
Suerte.
Jan 24, 2008 | Panasonic NN-S768BA/WA Microwave Oven
Kohler 12 kW Emergency Power System - 12RES-L Logo
Top Kohler Electrical Supplies Experts
Sheldon Dedek
rjivaro
J. Bradshaw
Are you a Kohler Electrical Supply Expert? Answer questions, earn points and help others
