Yes, but you need the pre weighed grommets from bunn, if you remove the top panel on the machine you will see the brew tank, within that there will be brown plastic shaft with a yellowish cylinder on top of it. There might be 3 or 4 washers on top of that yellow piece, those are the weights, when the water fills the tank it pushes the float up and when it reaches the top it turns off the solenoid. You should be able to try it without the top on.
