Reboots no POST every 5 seconds
Http://downloadmirror.intel.com/15051/eng/DP35DP_TechProdSpec.pdf
BIOS-RECOVERY.
PAGE.58-61 ARE INTRESSTING.
Disconnect from power. remove case cover and remove motherboard battery/power cell. leave unplugged for five minutes the n re-insert battery and power up. All peripherals should also be switched of at the power outlet. IF,after having performed the above procedure, the fault still occurs it is probable that you need a new motherboard.
SOURCE: help with an intel dp35dp motherboard
Hi superdarien, you can click on this link for a little help with installing a motherboard. http://www.hardwaresecrets.com/article/145
Connecting power from the power supply to the motherboard.
There are a few connections from the PSU to motherboard & they are important. Please open you're motherboard manual to page 11 & 12.
The letters M & T are the two most important connections. M is a 4-pin ATX_12volt plug. It can only be connected one way. There is a small plastic locking clip on the connector. Letter T is the main power connector. It as well can only be connected (one way). There is also a locking clip. (Plastic). Look at the 24 pin connector on the board. http://www.brainbell.com/tutors/A+/Hardware/Power_Supply_Connectors.htm
You do not need to be a geek to hook this stuff up. You're manual will help you more than you think. Bouncing from page to page is the hardest thing to do. When you come across terms you do not understand type the term into a google search. This will help.
SOURCE: about motherboard
asus p5nsli has a lot more options as compared to the intel. it also supports overclocking so you will be able to boost your processor when the time comes :)
SOURCE: intel DP35dp motherboard
sounds like you "might" be having a capasitor starting to fail look at your cap's to see if any have a dome look insteed of flat like the rest if so you have 2 options have the cap's replaced (some tv repair shops will cost $5.00 per cap for $50.00-179.00 or upgrade to a new mother board if you know someone who talks ham radio they can fix it also if they have the equipment
SOURCE: "Reset you're cmos/bios jumper to
HI,
No need to worry. There are many known ways to reset / remove / bypass the password:
Now I'll try to explain each method one by one:
A. By Removing the CMOS Battery:
Almost all motherboards use a small coin sized CMOS battery to store
all BIOS settings along with the password. To reset the password, unplug
the PC, open the cabinet and remove the CMOS battery for approx. 15-30 minutes and then put it back. It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings.
If it fails, then try to remove the battery for at least one hour.
B. By Using the Motherboard Jumper:
Almost all motherboards contain a jumper that can clear all CMOS
settings along with the BIOS password. The location of this jumper
varies depending upon the motherboard brand. You should read your
motherboard manual to check its location. If you don't have the manual
then look for the jumpers near the CMOS battery. Most of the
manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and
the jumper will be joining the center pin to either left or right pin.
What you need to do, is remove the jumper and join the center pin to the
opposite pin. e.g. if the jumper joins center pin to left pin, then
remove it and join center pin to right pin. Now wait for a few seconds
and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
C. By Using MS DOS Command:
This method works only if you have access to the system when its turned on because this method requires MS DOS. Open Command Prompt from Programs menu and provide following commands one bye one:
debug
o 70 2E
o 71 FF
quit
NOTE: The first character in the above commands is "O" and not the number 0.
After providing the above commands, restart your system and it should reset the CMOS Settings along with the BIOS password.
If you are curious to know how it works? then let me explain the above commands:
In this method we are using the Debug tool of MS DOS. The "O" character present at first in these commands, outputs the values to IO ports. The number 70 and 71 are port numbers which are used to access CMOS memory. By providing FF value we are telling CMOS that there is an invalid checksum and it resets the CMOS settings as well as BIOS password.
SOURCE: cmos battery becomes bad in 4-5 days after
it's while booting cmos battery not working comes on the screen ...i have replaced 4-5 battery in a month
