Motorola Mobility RAZR V3i Cellular Phone Logo
A
Anonymous Posted on May 22, 2014
Why do i have no sound at all no ringer no message alert or alarm tones ?
  • Official Brand Answer 1,623 Answers
  • Posted on Jan 05, 2015
Motorola Mobility
Level 0:
Answers
1623
Questions
0
Helped
350754
Points
5677
Is phone set to silent?
Mark
Motorola Support
3 Related Answers
A
Anonymous
  • Posted on Mar 01, 2008
SOURCE: sound
try to master your phone
Anonymous
  • 7752 Answers
  • Posted on Jul 03, 2008
SOURCE: unable to change the message alert tone
you must have the firmware on the phone reflash, so take the phone to a mobile center and have it reflash onto the phone.
Anonymous
  • 17 Answers
  • Posted on Sep 04, 2008
SOURCE: message alert tone
hi there ,
             you have to enter settings , tone settings, then you select loud , then select loud details , you can change the message tone , the alert tones , the ring tones from there.hope this helps..
Simon
3answers
Where or how can you turn your ringer volume up or down
Hello Hank,
When you make call use the left and right square key for increasing or decreasing volume.
Apr 15, 2011 • Nokia 2600
How to increase the volume of the alarm?
All you have to do is...
This simply means that the alarm tone you are making use of is not loud enough to alert you at the appropriate time.
What you need to do is to make a change of the alarm tone from your phone ringer settings, while doing this, make sure you click or select a louder ringing tone from the ringing tone setting.
with the above information, you will be able to increase the volume of our phone alarm to give you the appropriate alert when needed.
3answers
I cant set my message tone on my samsung champ gt c3303, how can i change the message tone? please help...
On the menu go to -> settings -> sound settings -> ringer type -> messages -> text message -> my ring tones -> pick your sound here.
Nov 02, 2010 • Cell Phones
1helpful
Not working ringer
menu
2 settings
3 tones
incoming call alert (set to ringing)
ringing tone ( pick your ring tone)
ringing volume (set to level 5 loudest)
vibrating alert (on)
message alert tone (pick tone)
instant message alert tone (standard)
keypad tones (on)
warning tones (on) this is for the alarm and ringtone this is where your problem is so double check these settings ok
alert for (all calls)
Jul 03, 2009 • Nokia 3100
8helpful
On the LG VU CU920, how do you set ringtones as message alerts?
After going through the manual and talking to an AT&T rep, I found that it is not possible to set your own ringtone as a message alert tone. You can only use your own ringtones for calls and ringer ID's. We're stuck with the 10 pre-loaded rings for the message alerts. :(
2helpful
I cant change my message alert tone and alarm tone I also cannot select my own sounds or mp3 as alarm/message alert tones.
I contacted LG about the same thing. The only message tones are the 4 that are on the phone. This phone cannot use mp3's as message tones ot alarm tones.
1helpful
Mobile phone - message tone alert?
I do not have the phone or the manual...however here are my recommendations from the phones i have owned.
In the phone settings there should be a sound tab. This allows you to select rigntones and alert tones and alarms. Also there are different profiles that you can select ie: Normal- will play ringtones and all audible alerts and alarms...Silent: Will vibrate only and not play any sound ( even though you have selected a certain sound to play)....hope this helps
May 05, 2009 • Cell Phones
1helpful
4answers
Go to Menu, Click on settings, Audio & Ringtones, Message Alert Tones.
2answers
Samsung E900
Sound settings Use this menu to customise various sound settings.
Incoming call
Use this menu to select a volume level and alert type
for incoming calls.
Alert type: specify how you are to be informed of
incoming calls.
Ring tone: select a ringtone for the call ringer.
Volume: select a ringer volume.
Keypad tone
Use this menu to select the tone that the phone
sounds when you press a key.
Message tone
Use this menu to set up the ringtone for incoming
messages.
Menu functions
Tone: select one of several message tones.
Alert type: specify how you are informed when a
message comes in.
Repetition: specify how often the phone informs
you of a new message.
Power-on/off tone
Use this menu to select the melody that the phone
sounds when it is switched on or off.
Slide tone
sounds when you open or close the phone.
Silent mode
Use this menu to set how the phone acts to alert you
to a specific event in Silent mode.
Extra tones
Use this menu to customise additional tones for the
phone.
Minute minder: set the phone to beep every
minute during an outgoing call to keep you
informed of the length of your call.
Connection tone: set the phone to beep when an
outgoing call is connected to the system.
Alerts on call: set the phone to beep when you
receive a new message or when the time for an
alarm comes during a call.
Indicative tone: set the phone to beep when a
pop-up window displays.
2helpful
3answers
Ringer doesnt work Nokia 3120
hi follow these instructions
1 menu
2 settings
3 tones
keypad tones (on)
once you have done them settings try your phone and see if it works if not then follow these instructions
1. menu
2 settings
3. profiles
4 general then personalise
the set like this
Incoming call alert (ringing)
ringing tone (choose ringtone)
ringing volume (level 5 )
message alert tone (choose tone)
Keypad tones (on)
warning tones (on)
once you have changed the last setting press back then select activate your phone should be now be working if not let me know ok
Mar 21, 2008 • Nokia 3100
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
