Rheem RTG-66DVN Direct Vent Natural Gas Logo
A
Anonymous Posted on May 22, 2014
How do I fix Rheem PTG2-42PVN ERROE CODE 11? - Rheem RTG-66DVN Direct Vent Natural Gas
Gene Haynes
Level 3:
  • Rheem Master 5,391 Answers
  • Posted on Dec 21, 2014
Gene Haynes
Rheem Master
Level 3:
Answers
5391
Questions
0
Helped
2606184
Points
14124
1helpful
Rheem Integrity 20 not always lighting. Showing code C2 11
Before calling service technician, open following links for Rheem/Paloma troubleshoot resources including error codes:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/No-Error-Code.pdf
C2 11 is no ignition.
Clean combustion parts yearly as recommended in manual is first step.
Other causes can be loose wiring, bas gas valve, dirty air intake, bad venting, bad sensors etc.
Test these parts using service manual. Call Rheem since Rheem does not post service manuals.
2answers
I have a paloma tankless water heater ptg-74pvn-2 that gives me the error code c2 11. looks like everybody has a problem with this. what can i do to fix it, surely enough they should have some easy way of...
Easy solutions for C2 11:
Rheem is one of the big manufacturers but has disproportionate number of questions at fixya since they try to funnel problems through service techs instead of posting do-it-yourself service bulletins. People want do-it-yourself service bulletins, as appear on the Bosch site for their products. Easy-fix in this sense would be to buy Bosch, and read service manuals aforehand to see if you have testing skills and equipment to maintain and repair tankless water heater.
Easy solution for C2 11 Rheem problem is don't install gas tankless water heater, since all costs are energy and tankless are expensive to install, maintain, repair, and replace for the mere savings of 1-8 per month.
Third solution for C2 11 no-ignition is to clean burner and combustion parts, and sand carbon off the igniter, on a yearly basis, as recommended in manual.
Fourth solution is to call a qualified service technician each year as recommended in manual, and have technician fix problem and catch water heater up on recommended service. This person can check other causes for C2 11 such as bad igniter, bad gas solenoid, low gas pressure, air in gas line, improper unit grounding, bad wiring, bad sensors, etc.
This check-up can also make sure vent drain is working properly and that acidic water vapor and other resulting combustion by-product are going into the household drain and eventually out to sea instead of dripping down into the heat exchanger causing rust and premature failure of exchanger.
Next solution will not solve C2 11 error code, but can address other error codes before they happen: Maintain water heater on yearly and monthly basis as recommended in manual. This is good for folks who like projects.
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
More resources:
1-800-432-8373
http://waterheatertimer.org/How-to-install-gas-water-heater.html
3helpful
2answers
I am getting a C2 11 code on my eco sense tankless water heater. There is also a flashing 24, any ideas? Thanks
Multiple error codes can mean PC board failure.
Error 24 is malfunction of operational switch: "press max or mim button on PC board, or replace PC board." On some models, max and mim button can be located just above dip switches, and rotates with screwdriver. See diagram in manual.
Before calling service technician, open following links for troubleshoot resources including error codes, Rheem chat, and possible manual.
http://waterheatertimer.org/pdf/ErrorcodeTroubleshooting.pdf
1helpful
2answers
We are getting multiple codes. Can someone help us. Last year we got cod c2 11 which we found out we just have to clean the probes in the unit. So we did that yesterday again and everything worked great,...
Rheem, Richmond, Ruud, and Paloma are all the same manufacturer. After about 9 months, my tankless RTG-74PVN started giving me error code 11 and cold water!. I fixed it by cleaning the burner, as shown in this video:
www.howtolou.com/clean-a-burner
5helpful
4answers
C2 11 code
Before calling service technician, open following link for Rheem error codes and troubleshooting resources:
Error code C2 11 is 'no ignition'
Ensure you have gas to the appliance.
Ensure gas type and pressure are correct.
Bleed all air from gas lines.
Ensure gas line, meter, and regulator are sized properly.
Ensure appliance is properly grounded.
Check gas solenoid valves for open or short circuits.
Ensure igniter is operational.
Check igniter wiring harness for damage.
There is no service bulletin covering how to perform these actions.
Rheem will ask that you call qualified service technician, who can give you tips and tricks for keeping the unit working, including opportunity for yearly service that will eliminate the expected $1-8 monthly savings from owning tankless.
Read manual for yearly maintenance needed to keep unit working at prime efficiency.
1helpful
2answers
Replaced mother board due to error code c2 11 as per rheem tech department. now code 11 flashes after 3 to 4 minutes of use and unit shuts off. WHAT NOW????
2helpful
3answers
I have an error code of c2 11 on rheem model number ptg-74pvn-2 I will get warm water for about 5 seconds and then it goes cold
www.howtolou.com/clean-a-burner -Lou
1helpful
2answers
Problem for Rheem Paloma PTG-74PVN / RTG-74PVN Natural Gas Indoor... What does C2 11 error code mean on my Paloma
hi pete here ill try and help this could be 2 things check the sensor on the unit the outher one is a qustion has the gas company changed your meter latley and turned off you gas and not come back to light your poilet because this code also means not enough gas or wrong type of gas
2answers
I have a Paloma PTG-74PVN and I ain't getting any hot water and its showing c2-11 error code. How can i fix this problem
could be overheat stat or fan check the little hose at the fan area for pinhole next choice diaphrapm valve then micro switch best of luck
Top Rheem Water Heaters Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
