I used my cushion one evening and it was fine then the next time i went to use it the lights on the control did not light it has no power no movement and no lights i have changed the fuse on the control but it still wont light can you help please
The skid steer has an operator presence switch located underneath the seat cushion. This switch is what turns on the seat light and this is what stops the movement an operation of the skid loader. The problem could be a variety of several problems. The simplest is, 1. maybe you or the operator is not heavy enough to activate the switch, 2. The cushion of the seat may be to stiff. 3. The switch itself bad. 4. Wire to the switch broken or shorted to ground. 5. Check the fuses. Check all the simple things first.
Good Evening, I can certainly understand your problem. I have seen this a number of times. The first thing to have checked out is your motor mounts (as long as your engine is running smooth I would not say a misfire) the mounts get a good amount of wear and tear and what happens in drive it relies on those mounts to help cushion the movement of the engine. I hope this of some help. Thanks, Joey
frist chack your Adeptor if it's working then just chack your bettry
if this two devices are wroking then you have to go for technition becoz may motherboard and HDD prob
remove and, clean your battery cable clamps then retighten and, test.
If your battery is too discharged "jump" it using jumper cables and, another car.
