I have a 50" Panasonic Viera LED tv, just two years old. Switched it on today and screen came on and immediately went black, no sound and nothing at all on screen. Plug fuse ok, tried switching off for 10 mins (unplugged) power is getting to the tv as green light comes on and blinks a couple of times but then goes off. Is this a common problem and how can it be fixed?
SOURCE: no power
Bring your Tv to Micro Electronics
1515 Britannia Rd E, Unit 12
Mississauga Ontario, L4W 4K1, CANADA. ask them to chek it out, they are the best, they will let u know is it possible to fix or not, how much its gonna cost you, if its fixable and can get the parts you will get the tv in ur hand next day. call them 905-565-6595
SOURCE: Panasonic 50 inch Plasma
it could have over heated you can try to reset it first unplug it for about five minutes and try to turn it on if that dont work the remote might have a set button try holding that down until the red light flashes twice, then turn it on if not then hold the power button down on the set for a good five seconds to see if that resets it. if none of that works you will have to go to panasonic .com for the reset instructions.with the red light blinking the power supply is most likely good you just need to reset i.
SOURCE: Philips 42 in. Plasma shut down
Thank god we purchases the ADVANCED extended warrenty. This tv has been nothing but problems.
Fuzzy picture, picture shutting off after 20 sec coming back on and now blog of colors shut off never to come on again. 7 blinking red lights on the front. Waiting for the repair man again.......
SOURCE: TV SCREEN GOES BLANK
Yes your inverter is bad, I have the same problem my set is about 1 and 1/4 years old. Because Olevia makes a terrible product there inverters are attached directly on to the panel, which means they will only sell the inverter along with the panel i.e $700+ to replace + $100 dollars labor if u don't know how to fix it ur self. I am currently searching to find the manufacture that makes the inverters because olevia will not disclose that information. I believe it is darfon, if so the inverter should cost about $150-200 depending. If you dont believe you can fix it ur self ur best bet is try and sell the set for scrap take ur $100 or so dollar and buy a quality product! Oh and dont call there support they will tell 10 different things before u find out this long for seen truth!
SOURCE: Sharp Aquos LC42D62U with blank black screen, good
Unfortunately not really, it is the video board of the LCD that has failed, it is a major repair to say the least. You can check with a local repair shop to estimate the repair, but it will be spendy :(. I'm so sorry about the bad news there, but that's definitely what it is. If you happened to purchase the TV with a major credit card (not a debit card) there is a good chance it may still be under the free extended warranty most credit cards place on electronics. Please contact your credit card company to inquire if they do this, and they will be able to file the claim and get you a refund for the TV.
Thanks
Tim
