I've uploaded the Kadio KD-6128 manual to MegaShares. The link is: http://d01.megashares.com/dl/yEh7e83/Kadio KD-6128 StopWatch Alarm Chronograph Manual.pdf .
SOURCE: Kadio KD-2024. How to change the time.
unfortunately there is no online access to KADIO. One thing is for sure: M stands for MODE; S stands for SETTINGS; D probably stands for DAY/DATE. To set the watch first you have to push the S, then choose the M and then goes the rest. I can't give exact directions, as this is Chinese made watch and no details can be obtained.
SOURCE: how to change day in kadio kd 3806 wallclock
i do not know how to fix the time and the date and month in Kadio KD-3809 Digital Wall. Can you please help me? My son just lost the brosure and i am trying to fix it but I can not do it.
Thank you!
SOURCE: how to set the clock
http://www.fixya.com/support/t6744593-change_time_kadio_clock_3809 for solution
SOURCE: KADIO KD-3806 Model watch.
ALL PARAMETERS CAN BE ADJUSTED BY USING KEYS
GIVEN BACKSIDE...KEYS ARE
MODE (LONG PRESS-4 SEC) TO ENTER INTO SETTINGS;
UP/DOWN TO CHANGE THE PARAMETERS; \
*C/*F KEY TO TOGGLE BETWEEN TO TEMPERATURE FORMAT;
SNOOZE BUTTON TO SET SNOOZE IN ALARM-MULTIPLE SNOOZE CAN BE SET;
RESET KEY CAN BE USED TO RESET CLOCK TO DEFAULT;
DAY COUNTDOWN , AND TIME COUNTDOWN CAN BE ADJUSTED;
DETAILED INFORMATION TO SET THE CLOCK
INSERT CELLS;-SCREEN SHOWS DEFAULT VALUES-INITIAL MUSIC WILL RING;
LONG PRESS MODE BUTTON-KEEP IT PRESSED UNTIL 12 STARTS BLINKING;
USE UP /DOWN BUTTON TO ADJUST HOURS...
THEN SIMPLY PRESS MODE AGAIN, NOW MINUTES 00 IS DEFAULT WILL START BLINKING;
USE UP/DOWN BUTTON TO ADJUST MINUTES;
AGAIN PRESS MODE, SCREEN WILL SHOW YEAR 2002 DEFAULT BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW MONTH BLINKING, USE UP/DOWN KEY TO ADJUST CURRENT MONTH;
AGAIN PRESS MODE, SCREEN WILL SHOW DATE BLINKING, USE UP/DOWN KEY TO ADJUST YEAR;
AGAIN PRESS MODE, SCREEN WILL SHOW 12:00 BLINKING WITH ALARM SIGN (FOR ALARM SET);USE UP/DOWN KEYS TO SET ALARM, FIRST HOURS AND THEN MINUTES FOR ALARM; THEN ON PRESSING YOU CAN SELECT SNOOZE MINUTES;
AFTER SNOOZE ON PRESSING MODE AGAIN YOU CAN SELECT DAY COUNTDOWN TO SELECT 999 DAYS COUNTDOWN FROM CURRENT DATE;
when watch displays time and everything .....
each and every buttons has some function;(shortcuts)
press down to toggle between 12hr/24hr format;
press up to enter contdown timer;
press snooze to set snooze in alarm;
press c/f to toggle between two temperature formats;
press mode to toggle between alarm time and current time
