Hello - the fridge part of my Bosch intelligent frost free 44 is not cooling properly. The freezer is working exceptionally well but the fridge is not cool enough although it appears to still be operating. The fridge is also making loud irregular cracking noises. Do you have any advice please? Kind regards, Nicole.
SOURCE: bosch intelligent frost free 40
The small drain pipe on the back of the fridge gets clogged, hence no drainage when defrosting, hence ice blocks the airflow between the freezer compartment and the fridge compartment.
Remove the rubber stop from the drain pipe and clean (can be found above the motor)
Defrost the fridge for a few days (it takes at least 48 hours). During this time, if you are not brave enough to remove the internal panels of the freezer and continually clean the water, check for water coming out and clean.
If during the defrost there is no water coming out the drain pipe, use about 2m of flexible and strong wire to clean the pipe.
The aim is to unblock the pipe once the ice has melted.
