Oster 3212SNB Food Processor Logo
Steve Mullis Posted on May 22, 2014
My Oster 3212 food processor will not turn on.
Please advise. It has been very used rarely and always had very light use. After turning the food container and locking it in place I press either of the start buttons but nothing happens. No sound, no grinding sound from the motor. Nothing. Please advise. Thanks.
svanegdom505
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Jun 13, 2014
svanegdom505
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
Helped
6734
Points
13
You have to make sure that both the bowl and the cover are locked into place. Sometimes if you wiggle it a bit, it will go into the right spot. Make sure that the outlet you are using works.
1 Related Answer
Steve Mullis
  • 15 Answers
  • Posted on Jun 25, 2009
SOURCE: I need a replacement bowl for the Oster 3212 Food Processor
I contacted the manufacturer and bought the bowl. This is frustrating as I had contacted their authorized service center and was told the bowl was unavailable.
My Oster food processor FPSTFP5273DFL won't turn on?
Keep one hand on the top of the food chopper. And turn the blender on using the medium speed on continuous or fast pulse settings
1helpful
I need an instruction manual for a Oster Food Chopper FPSTMC3321
Oster has not made a manual for your specific model available online. The User Guide for the Oster 3320 3-Cup Chopper with With Attachment, which appears similar to your model may be of assistance. This User Guide may be downloaded here.
2answers
Oster 3200 processor but have no blade shaft and cannot find on line. Do you have or know where I can purchase one?
Hi there.
Try http://www.oster.com
You will be able to find authorized parts dealer near your area.
Regards.
2helpful
2answers
Have a sunbeam oster kitchen centre....mixer,blender, sausage maker...but no manual..1985 -86 model...help. #97108C ON MAIN BODY.It has stainless bowls, glass blender jug. Sure would love a manual.Thanks.
I have an Oster Kitchen Center by sunbeam. It has the mixer, blender and food processor. When I attach the processor to try to use it the blades do not spin. If I push the siler know down with an objest it will turn. Am I missing some little piece to make it work.
2answers
Just purchased Oster 3322 food processor and cannot get it to work. Have used various brands and know that this unit has been properly assembled. Neither the 'on' or 'pulse' buttons will activate the...
Oster is a good brand. Unplug it and try to turn thhe motor by han using an attachment. Or, tap the unit with a run button depredded. Here is why. Sometimes new brushes on a motor have a coating on the conrtact surface. It is vry thin and it is not permitting a good electrical contact. If you can't turn the motor, slap it a couple of times with it on. Once it starts, let it run for 2 or3 minutes and you troubles are over once the brushesseat and clean up. Good luck and remember to unplug when hands are on or near the attachments.
I have a small Cuisinart food processor and I cannot figure out how to turn it on. It has two levers low and high. I have it plugged in and the lid on? Please help. Fiona Slattery 858-752-8591
Your PowerBlend Duet™ comes with a food processor button. This button is the perfect speed for all your food processing tasks. Always use this speed when using the food processor. You may also use the Pulse button with this function for pulse-chopping.
To use your food processor, make sure that the bowl is assembled properly and the blade or slicing/shredding disc and the cover are locked into place.
When you use the control panel, the LED will light next to each button you press.
Press the On button. For continuous operation, press the Food Processor button. Motor will start if you have followed assembly instructions.
To turn motor off, press the Food Processor button again or the Off button.
For on/off operation, called pulse-chopping or pulsing, press the On button, press the Pulse button, and then press and release the
Food Processor button the desired number of times. Motor runs as long as you hold the Food Processor button down. The motor stops when you release control switch. Try it a few times.
You control the duration and frequency of pulses by the length of time you hold the Food Processor button down and the rate at which you press it. Pulses should be short bursts. Allow enough time between pulses to let food in work bowl fall to bottom.
Always use the Food Processor button for pulse/chopping. Never turn cover back and forth to start and stop processor.
You can download manual from the below link
http://www.cuisinart.com/share/pdf/manuals/bfp-10ch.pdf
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
2helpful
3helpful
2answers
No instruction manual for Oster 500 watt 3200 Food Processor
http://www.oster.com/manuals/oster/003200-000-000_English.pdf
you will need the free adobe acrobat reader if you dont already, chances are you do, I found this at oster.com
Top Oster Food Processors Experts
ADMIN Andrew
ADMIN Andrew
john h
ADMIN Eric
ADMIN Eric
Are you an Oster Food Processor Expert? Answer questions, earn points and help others
