Hisense LCD1504 15 in. Television Logo
A
Anonymous Posted on May 22, 2014
Hisense tv worked yesterday with antenna reception, today it continulaly asks to run channel auto scan, which i have done repeatedly, antenna is not broke, tested it on another tv
3 Related Answers
Anonymous
  • 32 Answers
  • Posted on Mar 15, 2009
SOURCE: sound does not work on several channels on Hisense LCD1504
RESTART THE AUTO CHANNEL SEARCH IN YOUR MENU. LET ME KNOW IF FIXED. THANKS.
drbelitz
David Belitz
  • 93 Answers
  • Posted on Oct 24, 2016
SOURCE: I have a Hisense TV and am trying every antenna to get local channels but it searches and finds no channels... Frustrated... I don't have cable or wifi any suggestions?
You need to find out the miles between the t.v. and the nearest broadcast antennae. Call a few t.v. stations. Then buy the proper distance antennae with outdoor attachment for window.
Hope that helps.
rostit
  • 746 Answers
  • Posted on Jan 02, 2018
SOURCE:
Your TV is now trash.
HiSense 55 in smart TV. Digital Antenna
This will be a main board issue, replace the board and the set will work like it's supposed to. I would take another TV and run a channel scan and be sure your antenna is picking up the channels before ordering a main
1helpful
2answers
I have a Roku hisense 32". It is set up but how do I re-scan for antenna channels?
First make sure that you have the antenna connected to the RF jack. Go to the Home screen of the TV and select the Antenna TV tile on the right hand side of the screen. (If you acquired the TV from a previous owner, they could have hidden this tile. See the steps preceded by Otherwise.) If this is the first time you scanned for channels, just follow the onscreen prompts (including setting your time zone). Otherwise, go to Settings (below Home in the left column on the home screen) > TV Inputs > Antenna TV > Scan again for Channels > Start finding channels. Use the arrow keys to navigate the menus/tiles and press OK to enter. To save, make sure to select Done and press OK.
The manual for the Hisense Roku TV (2019), 32HF4030F is available here: https://www.hisense-usa.com/support/models/32H4030F_hd-hisense-roku-tv-2019 . The current link to the manual is https://assets.hisense-usa.com/assets/ProductDownloads/88/c8c9a74079/Roku-User-Manual.pdf . The section for setting up TV channels starts on page 39 of the manual. See the section starting on page 10 for information on using the remote or TV front panel buttons in the menu.
I hope this helps.
2answers
2helpful
How can i get the channel auto scan on my Hisense 55h6sg tv to find any channels.
If it is asking for zip code you have not told it to scan for over the air or antenna channels when it asks air or cable
I have older vizio tv that is picking up 12 of the 15 possible digital chanels, plug my newer vizio in and got all 15 chanels is there something I can do?
Try using the TV's on-screen menu to manually add the channels or run another auto-scan. If done manually and the TV has no reception on these channels, the best you can do is to purchase a digital antenna which will provide more channels to a poor built-in antenna.
TV displays "no signal" with every input type we try. The only thing that works is the DVD. I even tryed it on a cable cord that was working from another TV
hello are you using a digital antenna, cable or satelite reception? you need to run your "set up" and scan for channels either automatically scan or manual scan, recomend a auto scan for all channels both digital and anolog, these tv will scan and save or store the channels but you need to run a channel scan first,
(even if your using a cable box or sat box)
back when we had the older anolog sets you could just plug it in and watch but with these new digital circuts need to scan and store the channels in before you can watch the broadcasts,, try that let me know what happens. hope this helps
Bad/No reception problem on older tube tv worked good yesterday
have your tuner check for any cold solder on pins.
2helpful
VIORE PLC7V95 7'' portable TV, cant get channels when scan
I notice that on mine, the positioning of the included tv antenna is very, very, very finicky. I also don't know how to "add" a new channel other than to hook it to the big house antenna and pick "re-scan" (or auto-scan or whatever it's called).
So I think your best bet is to pick a better antenna or know that even the tiniest fiddling with the antenna makes a diff. Sometimes, I even have the antenna horizontal (using the magnet) to get the good reception on a given channel. Seems like a hassle except that what should I expect from a tiny antenna....
Problem with auto tune Sony TV
check the setting the of your antenna poor reception will not lock the tuner to it.
Top Hisense Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
MrFixitSTTL
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
