SOURCE: SHARP Viewcam z vl-Z500H-S Camcorder
To transfer video you need to use firewire, not usb. If you use firewire to connect, set the camera to the 'play' icon and then open up a capture program (ie, movie maker) you should be able to just record/capture from there. Good luck!
SOURCE: Download correct software to burn dvd off of camcorder
You do not need the manual, you need the white DV cable that comes with the view cam. it connects into the DV port on the left side of the camera theto the "Y" port located next to the usb ports in the front of the hard drive. Turn the camera to VCR and XP will automatically open the CD wizard and follow the prompts. then use any burning device on your computer, mine is Media Center to make a DVD. Its easy for those challenged like myself!
SOURCE: How do I make a DVD on my PC using my Sharp VL NZ100?
I am trying to make a DVD using my laptop which is windows vista and camcorder. I am using a USB cable but can not find it on a drive in my laptop
