Dishwashers Logo
K
Kristopher Posted on May 22, 2014
How do I fix a flashing Start/Resume light on a Kenmore Elite dishwasher model 665.13793K601?
I have a Kenmore Elite dishwasher 665.13793K601 and the Start/Resume button just blinks continuously. Before, it would run fine, just not drain. Replaced both circuit boards and after turning power back on the Start/Resume light flashes continuously. Tried a couple reset sequences found on different help sites that did not work. When other buttons are pushed, they will start flashing also. Is this a problem with the new control board, a stuck button possibly? Any help would be appreciated. Thanks
alstreck
Level 1:
Problem Solver:
  • Contributor 19 Answers
  • Posted on May 22, 2014
alstreck
Contributor
Level 1:
Problem Solver:
Answers
19
Questions
0
Helped
4765
Points
45
These dishwashers are known to accumulate moisture in the keypad and then short. The solution that I have seen is to replace the keypad...It is possible that all of your issues with this dishwasher could point back to the keypad. After spending $$$ on the circuit boards, do you want to throw and additional $135 for a keypad? or replace the whole unit? Food for thought. Here is a link for you:
http://www.repairclinic.com/PartDetail/Control-Panel/8572855/1180767?modelNumber=665.13793K601?RCAID=1000065
5 Related Answers
Anonymous
  • 878 Answers
  • Posted on Mar 03, 2007
SOURCE: Dishwasher's "Pot-n-Pans" light flashing
ga, behind the toe panel on the bottom there should be a tech sheet explaining how to put the dishwasher in the test mode. See if you can enter the test mode. If you can't, you probably have a stuck or shorted keypad. Catriver...post back
Anonymous
  • 1214 Answers
  • Posted on Jan 24, 2009
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Anonymous
  • Posted on Apr 18, 2009
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Anonymous
  • 949 Answers
  • Posted on May 23, 2010
SOURCE: The "clean" light is green, flashing.Dishwasher won't restart.
This is due to the water not heating properly. I have put together some instructions on how to reset the control so you can use the dishwasher again and what to check for as to why it failed. Follow the link and let me know if it was helpful.
Flashing Clean Light
michael
  • 155 Answers
  • Posted on Apr 07, 2011
SOURCE: The dishwasher won't start, its stuck, pots/pan
did you hold the start/resume button for at least 3 seconds if this works the dishwasher will start ok but if there is a fault it will fail again best you contact your nearest service agent good luck
Won't start, green flashing light next to start button. Tightened door screws last week. How do I fix this
KITCHENAID DISHWASHER REBOOT - YouTube
? 4:17
www.youtube.com/watch?v=XJnzzXJcOV4
Sep 17, 2012 - Uploaded by DIYAPPLIANCEREPAIR How to reboot your Kitchenaid, Whirlpool, Kenmore by Whirlpool dishwashers control board. ... Up next. Dishwasher Repair will notstart - Repair & Diagnostc - Kitchenaid - Whirlpool ... Kenmore Elite Dishwasher blinking light Control Board FIX - Duration: 1:37. by ... Dishwasher Buttons Not Working?
Kenmore elite dishwasher smart wash flashes
This sounds like a door switch that is faulty on your main door so the system gets a signal saying its not closed properly and there for signals fault
Dec 20, 2013 • Dishwashers
My Kenmore Elite Ultra Wash Dishwasher keeps shutting off before entering the cycle. I have repositioned dishes, even emptied it, changed cycle and tried everything. When I press the start light flashes...
I too had problems with the Kenmore Elite (aka Bosch). The issue was solved by replacing the Lock Sensor on the door. After replacing the sensor the dishwasher has been working. Hope this helps.
2answers
Kenmore Ultra Wash Model 665.1388 problem the normal wash green light is on heated dry light is on and the start resume light is flashing but wont startup helpppp
see your instruction manual and go to the section troubleshooting and fix it.
if you do not have the i.manual download for free www.retrevo.com or www.fitness.manualsonline.com
see the diagram
God bless you
I have a Kenmore elite dishwasher about 5 years old and it will not start. The clean button keeps blinking green. Tried resetting power and still it will not start.
Makeing sure you have power is my first step.
Ensure the door isn't ajar is another possible fix...(check that door switch.)
Pressing the start / resume button again after these steps are done is all Ive got left.
I hope this helps.
Four hour delay light flashing
I have a kenmore elite dishwasher and the 6hour delay light is flashing and no other buttons work when I push them.. whats wrong?
65helpful
2answers
Kenmore Elite Dishwasher clean light ind flashing and won't start
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Diswasher will not do anything...
"AIR DRY" LITE IS ON. I CANNOT GET TO GO BACK SO I CAN START IT AGAIN
Top Kenmore Dishwashers Experts
vince
Paul Carew
NOEL
NOEL
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
