No sound when installed. does the four channel amps xvoers need to be set a certain way?
SOURCE: need wire diagram for clarion 500EQA equalizer
Your installation manual is not anywhere to be found since the product you are inquiring about was made 1985-87... however, by deduction, you can figure it out yourself...
You need a Power 12V Constant.
A 12V Switched
A Ground
And Signal Cables.
Reply with the wire colors available to you, and I will tell you what is what.
Yellow is usually constant 12V.
Red is Ususally switched 12V.
Black Is Ground.
RCAs are self explanitory.
If your EQ has HI Level outputs, the color scheme is a little more complicated.
