Canon IR1022if Copier when printing in bypass tray stops after printing one page and message on LCD display says "Change paper size". We are using legal size paper(8.5inx13in). When we used the paper cassette and set it to legal same message pop up. But it has no problem with Letter and A4 size. We did fixed the settings at additional functions but doesn't fix the problem. Please help. Jam
SOURCE: I have a Canon Laser
I will advice you Press and hold the "Resume" button on the printer. Press and hold the "Power" button while holding down "Resume."
Release the "Resume" button. Press "Resume" twice. The indicator light will turn amber followed by green.
Release the "Power" button. Press the "Resume" button four times.
Press the "Power" button. The error code is now reset, and your device should work fine.
Take care.
SOURCE: "wrong size paper"
Change the cofiguration of the size in your fax machine see if accepts them then
SOURCE: Canon LaserClass 7000 - Receiving problem
Make sure the rear guide is pushed up tight against the paper.
Remove all legal size paper and make a copy.
SOURCE: have a canon b95 faxphone machine.
Use the settings to select LGL as the paper size. (But note that you have to have legal size paper in the machine)
1. Press the Function key (left side, lower right button)
2. Press the Start/Copy key (right side, lower center button). The display will show USER SETTINGS.
3. Press the Left or Right arrows (right side, upper row) until you see PRINTER SETTINGS in the LCD.
4. Press the Start/Copy key
5. Press the Left or Right arrows until you see PAPER SIZE in the LCD.
6. Press the Start/Copy key
7. Press the Left or Right arrows until you see LGL
8. Press the Start/Copy key
9. Press the Stop key (right side, lower right button).
Testimonial: "Fantastic response. Clear and very helpful. Fixed the issue imediately. Thanks"
