I rinsed the engine compartment with dish soap and water and now it will not start. I let it dry, checked the plug wires at the coil and plugs, no moisture. I found water around the fuel injectors, dried them. When I try to get the codes with a OBD2 reader I get am ERROR message. DO you think I damaged the computer ?. It is located in the air box so it didn't get wet.
The engine compartment should never be washed with water. The electronic components are delicate and need to be dry to work properly. Sorry to bear bad news but you probably damaged the ignition system AND the ECU/PCM. You will need to tow your car to a licensed mechanic to replace the damaged components (maybe the whole electrical system in the engine compartment, but I don't know how far the damage goes). Next time, you should clean the engine with compressed air.
