Question about Jacuzzi BK37959 White Era?? Two-Piece Elongated Toilet BK37
Where may I obtain a replacement tank lid
I new a replacement lid for the tank and also a new mounting bracket Dan, zip 92629
    New Friend:
I am also looking for a replacement lead. Were you able to locate one since you posted your question? Any information I'm finding one would be helpful.
Posted on Nov 17, 2014
SOURCE:
Mount propane tank
The tank has openings in the handle or frame around the valve. These openings should slip over a mounting bracket on the grill frame under the control knob platform. You may have to loosen a thumb screw to loosen a retaining piece that helps secure the tank on the mounting bracket.
Jul 19, 2011 | Weber Genesis Silver A Grill
Just aquired a 1972 CB350 Honda, It has been sitting for years and I need to pull tank to clean it out. I know it just is rubber mounted and once rear is lifted, front slides to the back and tank comes...
Usually, the front seat bracket has a bolt in it that when removed will allow the bracket to come off then allowing the tank and ruber mounting to also lift off and slide back. don't forget to turn the tank to off position and remove hose from carberator first!
Sep 08, 2010 | 1972 Honda CB 350 F0
How to replace alternator on 2000 3.0 mitisbishi eclipse
  1. Disconnect the negative battery cable.
  2. Remove the headlamp washer reservoir tank.
  3. Remove the condenser fan and upper radiator insulator.
  4. Loosen the tensioner pulley and remove the alternator drive belt.
  5. Remove the alternator upper and lower mounting bolts.
  6. Remove the alternator support bracket mounting bolts.
  7. Remove the alternator support bracket from the vehicle.
  8. Disconnect the alternator wiring harness.
  9. Remove the alternator from the vehicle.
To install:
  1. Install the alternator to the vehicle and connect the wiring harness.
  2. Install the alternator support bracket to the vehicle and tighten the bracket mounting bolts to specifications.
  3. Position the alternator on the mounting bracket. Install and tighten the mounting bolt and nut to 17 ft. lbs. (24 Nm).
  4. Reinstall the drive belt and adjust the tensioner until the proper belt tension is achieved.
  5. Install the upper radiator insulator and condenser fan.
  6. Install the headlamp washer reservoir tank.
  7. Connect the negative battery cable and check the charging system for proper operation.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 05, 2010 | 2000 Mitsubishi Eclipse
Sun roof won't open, but i hear the motor turning
Check for any obstruction in the rail.
Also, can check this procedure to test your components...
Power Sunroof - REMOVAL & INSTALLATION (click over pic for zoom)
Motor
See Figure 1
  1. Remove the sunroof switch panel by pushing it to the side and disengaging the pawl, then pulling it downward.
Fig. 1: The sunroof switch panel is retained by a metal clip
  1. Remove the sunroof switch bracket.
  2. Unplug the sunroof motor wiring harness connectors.
  3. Remove the sunroof motor mounting screws.
Disassembly of the sunroof motor is not recommended.
To install:
  1. Lightly lubricate the drive gear with grease and install the sunroof motor to the sunroof assembly.
  2. Plug in the electrical harness connectors to the sunroof motor.
  3. Operate the sunroof to verify proper operation.
  4. Install the sunroof switch bracket and the sunroof switch panel.
Sunroof
See Figures 2 and 3
Fig. 2: Exploded view of the sunroof assembly on 1993-94 vehicles
Fig. 3: Exploded view of the sunroof assembly on 1995-97 vehicles-1998 models similar
  1. Tilt up the sunroof lid.
  2. Remove the lid side trim.
  3. Remove the lid bolts and the lid assembly.
  4. Remove the rear drain mount screws and the drain.
  5. Remove the shade assembly holders from the sunroof frame.
  6. Remove the shade assembly.
  7. Remove the sunroof switch, interior accessories and headliner.
  8. Remove the switch bracket.
  9. Remove the motor assembly, spacer and clip.
  10. Remove the wind deflector mount holders from the sunroof frame.
  11. Remove the wind deflector.
  12. Disconnect the drain hose.
  13. Remove the sunroof brackets.
  14. Remove the sunroof frame assembly.
  15. Remove the link and wire assemblies.
To install:
  2. Install the link and wire assemblies.
  3. Install the sunroof frame assembly.
  4. Install the sunroof brackets.
  5. Connect the drain hose.
  6. Install the wind deflector.
  7. Install the wind deflector mount holders on the sunroof frame.
  8. Install the motor assembly, spacer and clip.
  9. Install the switch bracket.
  10. Install the sunroof switch, interior accessories and headliner.
  11. Install the shade assembly.
  12. Install the shade assembly holders on the sunroof frame.
  13. Install the rear drain mount screws and the drain.
  14. Install the lid bolts and the lid assembly.
  15. Install the lid side trim.
Hope helps (remember rated this help).
Jun 03, 2010 | 1996 Nissan Maxima
How do you replace fuel pump 1993 camry
1992-96 Models
Be sure this procedure is done in a well ventilated area.
  2. Relieve the fuel pressure.
  3. Remove the rear seat cushion.
  4. Remove the floor service hole cover.
  5. Disconnect the electrical fuel pump wiring at the fuel pump assembly. Check for any fuel leakage while in there.
Fig. 6: Pull back the rug under the rear seat to access the fuel pump and sending unit cover
  1. Remove the gas cap, this will prevent any fuel gas spilling out of any high pressure lines.
  2. Using SST 09631-22020 or an equivalent line (flare nut) wrench, disconnect the outlet
pipe from the pump bracket.
  1. Remove the pump bracket attaching screws.
  2. Disconnect the return hoses from the pump bracket, then pull out the pump/bracket assembly.
  3. Remove the nut and spring washer, then disconnect the wires from the pump bracket.
  4. Remove the sending unit attaching screws, then remove the unit from the bracket.
  5. Pull the lower side of the fuel pump from the bracket.
  6. Unplug the connector to the fuel pump.
  7. Disconnect the hose from the pump.
  8. Separate the filter from the pump. Use a small screwdriver to remove the attaching clip.
  9. Inspect all of the lines, hoses and fittings for any sign of corrosion, wear or damage to the surfaces. Check the pump outlet hose and the filter for restrictions.
  10. When reassembling, ALWAYS replace the sealing gaskets with new ones. Also replace any rubber parts showing any sign of deterioration.
To install:
  1. Install the pump filter using a new clip. Install the rubber cushion under the filter.
  2. Connect the outlet hose to the pump, then attach the pump to the bracket and tighten to 22-25 ft. lbs. (29-34 Nm).
  3. Engage the connector to the fuel pump.
  4. Install the fuel sending unit to the pump bracket.
  5. Install the fuel pump and bracket assembly onto the tank. Use new gaskets. Tighten the pump bracket retaining screws to 34 inch lbs. (4 Nm).
  6. Connect the return hoses to the pump bracket.
  7. Install the service hole cover, then the engage the fuel pump and sending unit connector.
  8. Install the rear seat cushion.
  9. Start the engine and check carefully for any sign of leakage around the tank and lines. Road test the vehicle for proper operation.
Hope this help (remember comment and rated this).
Apr 09, 2010 | 1992 Oldsmobile Cutlass
How do you remove or drop down the tilt steering column on a 1989 F250 4x4 7.3 diesel? I'm trying to replace the clutch and brake peddle support pivot bracket that is broken. I've gotten the bracket...
this is for 1996, don't have 89.
these may be steps you need
  1. Remove pinch bolt from steering shaft flex coupling.
  1. Disconnect shift cable from selector lever pivot.
  1. Remove shift cable from steering column lower mounting bracket by pushing tab on cable in and sliding cable off bracket.
  1. Disconnect ignition switch (11572) by loosening bolt and removing connector. The bolt is part of connector and can not be removed.
  1. While supporting steering column, remove four retaining nuts.
  1. Disconnect collapsible intermediate shaft from U-joint at lower end of steering column.
  1. Remove steering column from vehicle.
Oct 29, 2009 | 1989 Ford F 250
I need to remove the fuel filterbut dont know how
Underneath the truck,just in front the gas tank, there is a hose coming from the tank.
Mounted to the frame with a "strap" type bracket,
is your fuel filter. When replacing this you must be certain to orient the new filter with the arrow pointing toward the front of the truck or away from the tank.
Aug 24, 2009 | 2002 GMC Yukon XL
Gas tank straps rusted & broke and need to replace. How do you get to the mounting brackets?
Strap mounts are right at the strap ends why can't you find them?
I use chimney strapping (get from most hardware stores) to make new ones. Paint them with undercoating spray to keep from rusting out.
Jun 26, 2009 | 1996 Jeep Grand Cherokee
Jacuzzi BK37959 White Era?? Two-Piece Elongated Toilet BK37 Logo
85 people viewed this question
Top Jacuzzi Home Experts
US Parts Center
US Parts Center
Mike
john h
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
