Hi, my Ka has had a new heater value but is still blowing hot air, ive turned the dail to cold and swtiched the heating of, yet hot air still seems to be comin out
what should i do ???
i dont want to take it to ford as there prices are very very high so any help would be great
thanks
Start car.turn on air conditioner high cool .raise hood look to see if the compressor clutch is engaged and running.if yes your ac air door could be stuck closed or the air door vacuum actutator not receiving vacuum.a vacuum line is broken or off. or the control switch bad.that control the AC and heater mode. if compressor clutch is not engagged.check for power at compressor clutch.if yes compressor clutch coil open. or the air conditioner refrigerant R 134 is low take car to a private garage with a good reputation. they wont be expensive as the dealership.have them hook car air conditioner to a manifold gauge set to check your refrigerant low side and high side pressure.
