Question about Mustek PVR-H140 Digital Media Player
How do I get my pvr to start again
Does not want to start its booting all the time then dl massage comes up, then 2==2 comes up, but dont start at all
How do I connect DGTEC PVR to Toshiba TV?
Hi Bronwen,
You might want to double check if there is cable loose or not connected to the right slot ( on the back of tv and pvr ).If still not work check the input lists and check one by one and there should be one of them is the right input. Hope it helps.
Apr 27, 2014 | Televison & Video
My laptoplid does not open
check power to laptop
what power led status on laptop is on then check bios massage on lid of comes then os boot massage on lid if not comes then go bios reset option and check again
May 16, 2012 | Sony Computers & Internet
I've installed windows xp SP2. 1st windows was succesfully formated and copying windows, then windows booting, and this massage appear "Press any key to boot from CD/DVD"... then i let it...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error if this fails to fix the problem
another possible reason could be a memory dump you might be running to many programs at the one time placing to much strain on the CPU also you might not have enough RAM random access memory to check what is running when your computer is running scroll to the bottom toolbar right click select task manager applications and processes if you see something you dont need running select end now to check how much ram you have click start right click on my computer select properties you will see all of your computers details another way to check how much RAM you have click start all programs accessories system tools system imformation all of your computers imformation will be there try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive this will schedule on a restart don
Jun 03, 2011 | MSI PM8M-V Motherboard
Code needed to link 320gbtt pvr to LG TV
Hi, I think there is a section in the LG manual that gives codes.I'm not 100% but I remember i had a LG 42pg6900 and that gave codes.
I hope this helps.
http://dl.owneriq.net/d/de5479aa-c05a-4234-e951-03e0026c75b7.pdf
you want page 64.
What make is your pvr.
I will try and help further.
Jan 23, 2010 | LG 42LC2D 42 in. LCD HDTV
Windows XP freezes with any network type enabled
I got the same problem before....but i just reformat it and only use the SP 2 and did not DL the other versions.....
Feb 25, 2009 | Microsoft Windows XP Professional With...
Kenmore Oasis has error code dl
The dL error code is a door lock error. The control board will attempt 6 times to lock the door before displaying the F dL error code. This is an indication that either the door lock is malfunctioning or the control board is not responding to the door locking circuit. Be sure the door is securely closed before attempting to start the washer. Open the door & check for clothing or something that may be stuck in the door boot area. If the door is securely closed & you still have the error code I would recommend having the door lock assembly replaced.
Good Luck and Please rate
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Installing a hard drive on the eurovox ex5000 pvr stops it workin
if the hard drive is new and not formatted , there will be no operating system for the computer to go past the bios start up
what you will have to do is to get into the bios , select boot preference and select cd as first preference
load an operating system( example win 8) and let the unit boot from the disc
after that has properly installed ,shut down the unit , restart and get the bios back up and change boot preference to hard drive
from then on it should start and boot from the program on the hard drive
Nov 13, 2017 | Televison & Video
Humax PVR 9200T freezing picture and will not turn off.
Unplug the aerial; switch the PVR On; if you have control via the remote do a reset to default settings thus:
1. press Menu on the remote
2. select Installation and enter default password of 0000 unless you have changed it
3. select Default settings and okay on YES
4. then turn if off again via the remote
5. plug the aerial back in and it will scan for channels, save them of course.
I got help on this from other forums but saw your request for help. This worked for me.
Oct 25, 2008 | Televison & Video
My mustek pvr-H140 freezing
Tje pvr-h140 basicall have 3 major components
1- 40 gb hard disk
2- battery pack similiar to the cordless phone battery packs
3- integrated panel with LCD and control buttons; usb port; power port; av in/out port.
when the unit hangs on initialize; this mean the hard disk is not responding. you can hit the recessed reset button and and power it back on. if the hard disk is OK this should clear up the issue.
if the hard disk is bad (crashed) then you need to replace the disk. Usually a fitjitsu 40GB notebook drive
also if the unit was dropped; constantly banged; etc then the cable to the hard disk to the integrated panel may be loose. The disk to cable is pinned and doesn't come loose but the other end of the cable is taped to the integrated panel and can come loose if the unit is not handled properly.
finally if the boot up files are corrupt; then you should be able to see it on the pc with the usb connection.
In this case you need to download and restore the files as discussed in the other solutions. Basically mustek has a website with all the drivers.
Jun 18, 2008 | Mustek PVR-H140 Digital Media Player
Mustek PVR-H140 Digital Media Player Logo
53 people viewed this question
Top Mustek Audio Players & Recorders Experts
John Elliott
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Mustek Audio Player and Recorder Expert? Answer questions, earn points and help others
