Pride New Mobility Legend 4 Wheel Scooter Logo
A
Anonymous Posted on May 21, 2014
I have a victory pride mobility scooter the battery is fully charged and it won't run I tried to reset but nothing worked
The batteries are only a few months old and when I push the levers to go forward or reverse it doesn't do anything
Lawrence Oravetz
Level 3:
  • Pride Master 10,558 Answers
  • Posted on Feb 24, 2015
Lawrence Oravetz
Pride Master
Level 3:
Answers
10558
Questions
Helped
2697209
Points
29284
Have the controller module checked. You can also download the service manual from Pride's website. It has a lot of information in it as well as a complete wiring diagram.
4 Related Answers
Anonymous
  • Posted on May 13, 2009
SOURCE: pride victory Scooter battery charged won't run
Its probably too late to give my opinion, but here goes anyway.
I had a similar problem with my mothers scooter and it turned out to be a faulty connection on the wires leading to the motor. I simply pulled the plastic connection apart, cleaned and lubricated the contacts, refitted the connection and all was well.
Anonymous
  • 3085 Answers
  • Posted on Jun 18, 2009
SOURCE: Forward/Reverse switch not working Revo Pride
Could it be in free-wheel mode. Most Prides have a pull up knob at the rear of the scooter.
oregoon
  • 175 Answers
  • Posted on Jul 09, 2009
SOURCE: I have a pride victory xl8. Problem - was running
All scooters have a protection system built in to prevent burning up the motor, and the user, should the scooter overheat. It sounds like yours overheated. If the temp. outside was warm to hot, and your weight is near the weight limit for the scooter, and you are taxing the motors over a hill, or unstable terrain, then the scooter goes into "limp home mode", or just enough to get you a bit aways, and then it will turn off. After a few minutes to cool off, it will go again, but shut down fairly quickly because it takes a spell to let the whole transaxle-motor assembly to get cool.
Check your weight, and anything else you may be carrying with you on the scooter. Check the terrain, and incline you are going against. Throttle down for all these occassions. If you overloaded the system at some point, then you may have overheated the brushes. Remove them (2) with a standard screwdriver and see if the copper coil is still flexible and springy. If not, replace it/them.
The damage may already be done, so it may need a new motor/transaxle assembly. An expensive proposition I'm afraid.
littleone121
  • 23 Answers
  • Posted on May 06, 2010
SOURCE: i have a old pride victory 3 scooter working well
It is best to let it charge at least over night, longer if it hasn't been used for a while. It is also good to give them a long workout (Don't completely flatten them though) at least occaisionally. If they get regular and thorough use they will last longer, but extra weight like shopping, or lots of steepish paths will flatten them a lot faster. They are only supposed to last a couple of years, but will go longer if you look after them.
One of the most important things is to find a supplier/repairman you can trust. These are, after all your legs or mode of transport you are talking about.
1helpful
Victory pride 2002 won't work?
hi Wendy it sounds like the batteries are so low that they can't even power the horn ?
check the batteries connection and the reset fuse situated at the rear .
regards
Rob
www.gewizrepairs.co.uk
Pride Victory 10 3 wheel , batteries fully charged power in and out of circuit breaker no power at controls nothing works all fuses are good no power there ?
If you have no power at the console but your batteries are good, check the connections of front to rear harness between the front/rear frame. If that connection is good, there may be a serious issue going on. For an authorized service technician in your area; please contact Pride Mobility.
My pride mobility victory scooter will not charge
You must charge each battery individually with an automotive NON automatic style battery charger until each battery has at least 10 bolts each. The scooter charger cannot pull up a battery with less than 10 volts.
My victory 4 mobilty wont charge the green light is very faint/the charger was tested working.so why wont my scooter charge
make sure battery cables are secure at battery terminals and clean.how old are the batteries.If the batteries run down fast they are no good.a good way to test them is put scooter against some thing solid and go forward.If the battery indicator drops to o the batteries are no good.It takes about 10 hours to charge the batteries
Victory 4 pride mobilty scooter,the charger dont seem to charge up the batterys. is the charger faulty.
DID YOU HAVE THE MANUAL? YOU CAN FIND THE RIGHT WAY TO CHARGE IF IT DO NOT CHARGE AT ALL MAY BE BATTERY IS BAD OR IF IT DO NOT CHARGER NOTHING PROBABLY THE PROBLEM IS THE ADAPTER, TRY TEST IT USING VOLTMETER OR POWER TESTER.
CLICK HERE MANUAL
1helpful
Pride victory mobility scooter
A fully charged battery should be over 12 volts. You may need to change your batteries.
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
