Question about Frigidaire Affinity 5.8 Cu. Ft. Electric Dryer
Clear codes for affinity dryer - Frigidaire Affinity 5.8 Cu. Ft. Electric Dryer
  • Official Brand Answer
  • 2,267 Answers
Hi Friend, this is Z. I am happy to assist you!
I see that you have a Frigidaire Affinity dryer and I'm presuming you are seeking information on how to clear error codes on your dryer. May I please have your model number? The serial tag, which lists your model number, is typically located on the upper front, as you open the door. With this information I can help pinpoint the exact problem. In the meantime, you can reset your dryer by either unplugging your dryer or flipping off the breaker for roughly ten minutes. This often clears most false error codes. Hope this helps!
Posted on May 25, 2014
  • Melissa R Anderson
    Melissa R Anderson Aug 30, 2016
    My Frigidaire affinity front loader dryer will stop running after 3 minutes and sure error code e44. What does this mean and how do I fix it?
SOURCE:
Error code e 91 for frigadare affinity dryer
most likely faulty control board...........
cheers
Apr 05, 2015 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
I am getting a error code E64 on Frigidaire affinity model# FASE7021NW0 It still get hot but keeps cutting off, what should I do
Hello friend, that's a great question!
From my understanding your Frigidaire Affinity dryer is displaying an error code of "E64". An "E64" error code stands for the heater circuit is open. This could be a possible problem with your heater, wiring harness, or even a miscommunication within your dryer. In order to clear out any miscommunication you can perform a reset on your dryer and to do that you need to unplug the power cord for at least ten minutes. If this does not help to resolve your issue I would recommend having a professional technician out diagnose and repair your dryer to help avoid any future issues or unnecessary part purchases. Hopefully this information is helpful. -Matt
Mar 02, 2015 | Frigidaire Dryers
Frigidaire Affinity Front Loading Electric Dryer. In about 5 minutes of starting the dryer, an error "Ad" shows in the window above the start button. Then the dryer stops and the lights under the "Ad"
I believe that code means auto dry. Lets make sure the lint and dust is clear from the machine. Check all of your wiring out well since is generally a cause. You may ave to replace the thermistor. Have you gotten any other code along with this.
Mar 04, 2013 | Frigidaire AEQ7000ES Dryer
Affinity Dryer code E66
It could be the door is coming open just enough to trigger the switch to the off position. Even though the door looks closed it could be partially open. Most likely the clips that hold the door shut are not tight enough that when the clothes hit the door it pops open a little bit. These clips are basically springs and over time they loosen up.
Aug 24, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Frigidaire affinity error code 12
Clear code, exit mode and start dryer. If problem persists, replace Main Control Board
Aug 17, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidair affinity dryer error code Ad
AD is not actually an error code, but is typically considered an Air Dry setting or feature on the unit.
Aug 06, 2012 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Frigidaire Affinity 5.8 Cu. Ft. Electric Dryer Logo
783 people viewed this question
Top Frigidaire Dryers Experts
Marvin
Marvin
John Tripp
John Tripp
Donni Steen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
