SanDisk 2GB microSD Memory Card Logo
A
Anonymous Posted on May 21, 2014
My memory card is not format in pc - SanDisk 2GB microSD Memory Card
Fred Block
Level 2:
  • Expert 289 Answers
  • Posted on Nov 26, 2014
Fred Block
Expert
Level 2:
Answers
289
Questions
Helped
166236
Points
608
Put your drive into a USB port; right click on that drive after it appears in My Computer and select Format; set the File System drop-down to NTFS (better file storage space) or FAT32 (more compatibility in older operating systems) and click Start.
1 Related Answer
Dll Rahim
  • 44 Answers
  • Posted on May 29, 2010
SOURCE: i cant format 2 gb sandisk memory card in my pc,
I would suggest that you have a corrupted inaccessible memory card. Your card is damaged and won't function properly.
How to format memory card using PC
If you format the memory using the PC then the memory card may not work in your camera. Format the memory card using the camera, go to the camera's menu and scroll through the settings until you come to Format the memory card, then select it and Format the memory card.
1helpful
2answers
Cannot transfer videos from pc directly to external memory, samsung star
To transfer pictures (via a memory card) to a PC requires a microSD Memory Card, Memory Card Adaptor & Memory Card Reader. The microSD memory card MUST first be formatted, by the phone, in order for the phone to create the destination folders. Please note that the minimum size limit for the microSD memory card is 32MB.
This phone will support the use of a microSDHC 16GB capacity memory card. However, for optimal performance Samsung recommends using a card no larger than 2GB.
To learn how to format the microSD memory card, using the phone,The plug-in microSD memory card and its contents can be easily damaged by scratches or bending. Use caution when inserting or removing the card and keep all memory cards out of reach of children.
Warning: Formatting a memory card will permanently delete all current content.
To format a microSD memory card follow the steps below:
  1. Insert a microSD memory card into the memory card slot, located under the battery cover
  2. From the standby screen, press Menu
  3. Press Settings
  4. Scroll down then press Memory Management
  5. Press Memory Card Details
  6. Press Format
  7. Press Yes to confirm formatting the microSD Memory Card
Caution!: Do not repeatedly format a Memory Card as this shortens it's service lifeWARNING: Formatting the microSD Memory Card will permanently erase all data
To transfer pictures (via a memory card), from the phone, to a PC follow the steps below:
  1. Insert the formatted microSD memory card into the memory card slot, located under the battery cover
    1. When correctly inserted, the memory card icon microsd2.gif is displayed
      1. From the standby screen, press Menu
      2. Press My Stuff
      3. Press Pictures or Videos to view the contents
      4. Press Manage
      5. Press either Move or Copy
      6. Press each image to check their box or press All to check All boxes
      7. Press either Move or Copy
      8. Press Memory Card
      9. Press either Pictures or Videos
      10. Press Paste Here to Move or Copy the Photo(s)/Video(s) to the microSD memory card
      11. Remove the microSD memory card from the memory card slot
      12. Insert the microSD memory card into the memory card adaptor
      13. Insert the memory card adaptor into the memory card reader
      14. Insert the memory card reader into the USB slot on the PC
      15. Navigate to the desired Photo/Video destination location, using Windows Explorer, then paste the Photo(s)/Video(s) into the destination on the PC
Regards.
1helpful
2answers
My memory card show to format it when i attach it to my pc but after formatting i cant able to use it now what can i do
Soory dude very sorry to say that your card will never work again.
who said you to format the memory card with your pc. You doen't, every phone has a format opt for formatting the card. And in every phone's manual it is written that "Format your card with your phone option. Don't format with your PC It will pemanently damaged your card". So, formatting your card with pc will damage your card for forever.
Jun 16, 2011 • Cell Phones
Samsung C322 is not reading the contents of the memory card. On clicking Menu> My Files, the contents of phone memory is displayed but the contents of the memory card is not displayed. Tried...
Your phone may be not supporting memory card format... or your memory card may be password protected... connect your memory with your PC and format it other file format. how to format memory card, do the following. 1 insert your memory card in card slot of your laptop or card reader or your PC 2. open my computer 3 right click on the memory drive or icon 4 click on format 5 change your file system 6 click start.
After formating insert your card in phone hope it will work for you.
Please do inform about dis, thank you
Apr 21, 2011 • Cell Phones
3helpful
3answers
My mmc card is corrupted how can i format mmc card
Hello DJB,
Formatting the memory card is a easy process. You can format the memory card from the format option available in memory card option itself. You can also format the memory card using the desktop pc or laptop. Remove the memory card from the phone and connect the memory card in computer using the external memory card reader and format the memory card.
2answers
My device needs to be formatted how do i do this
It is the memory card and use can either use the given connection cable to connect the camera to the PC or remove the memory card to be inserted to the card reader slot in the PC.
On detection of the card, you can right click for formatting on the card and start.
Mar 26, 2011 • Cameras
7helpful
When iam opening memory card in nokia 3110c it is saying memory card not formatted operation failed.please guide me what to do
Hi, problem can solved.When a memory card says formatted operation failed,it means the memory has been affected with VIRUSin it,thats why it's not given you access to get into it.
What you will need to do is to format it.
You can use your phone to format the memory card by going to the option of the memory card and click on format memory card.
Also you can use a PC to format the memory card by using a memory card reader. insert the memory card inside the card reader and connect to your PC, click on my computer, you will seethe memory card icon displayed, right click on the mouse for options to come up, and click on format memory card and you done.
Note: When trying to format and it does not format the memory card, that means the VIRUS that affected the memory has damaged it totally, that means you will have to get a replacement memory card.
Thanks for using fixya....
2helpful
2answers
MEMORy CARD NOT FORMATTED!
Yes! I can. Install "HP USB Disk Storage Format Tool" on your computer then use card reader. Now insert the memory card into card reader and then click on hp usb disk storage fomrat tool on desktop and now click on format. Your memory card will be format easily within seconds.
Good Luck
1helpful
2answers
Cell phone how do you format the sd card?
just go memory card in that u find format option
select that & ur memory card will get format or try connectioning ur mobile to pc & format through pc by selecting memory drive right click mouse button select format option in that asked for quick & custom format select one of them & format ur micro sd card
1helpful
2answers
How do i format my scandisk
If you are only using the card in a PC then when you plug the card into pc,it shows as a drive under my computer,you rt on the drive and pick format, fat.
If you are using a sd card for anything else such as a phone, you format the card with the phone,or whatever devise it is being used in, and you DO NOT format the card with the PC.
Top SanDisk Electronics - Others Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
