Hi! You may need to prime the trigger to get the solution flowing. To prime the trigger recline the handle and pump the trigger vigorously about 30 times. Power the cleaner on and hold the trigger in for 30 seconds. Be sure you are only using the Dirt Devil cleaning products intended for use with this machine. Using something other than the specified detergent can clog the lines that deliver the solution. If your cleaner still isn't dispensing you can take it in to a Dirt Devil authorized service center for repair. I have included a link where you may go to locate a service center near you. Hope this was helpful!
SOURCE: Dirt Devil Easy Steamer Deluxe
Follow the plastic extension that runs from the trigger through the length of the handle. This requires more disassembly that at just the trigger. At the end of the plastic extension you will find a triangular-shaped "ramp" that pushes against a "button" plunger that opens the valve that releases solution. When you release the trigger, the triangular ramp retreats and the plunger is supposed to be pushed back out by an internal spring in the valve. This plunger sticks because of accumulated soap from evaporated solution. Try cleaning that valve and plunger by running clean, hot water through the system OR replace the valve. In the future ALWAYS thoroughly flush the system with hot, clean water after using the machine.
SOURCE: dirt devil easy steamer need directions to use
Thank you for responding to my question. I should have spent some time really looking at my little machine. It wasn't hard to figure out -once I found and read the back of the cleaning solution bottle and tried my luck following the water to cleaner ratio.. Opening, adding the cleaning solution and water and re-closing the reservoir was pretty easy. Everything worked out fine...and my carpet is...spotless. Thank you, Cmarie
SOURCE: How to clean Dirt Devil Easy Steamer Deluxe Carpet
You can download manual here:
See page 9
http://www.dirtdevil.com/CustomerService/Manuals/DirtDevilManual.aspx?ManID=8fac8b06-4ad7-49a7-ac82-6f608a77a3bb
Please leave positive feedback if I have helped you
Thankyou
