Televison & Video Logo
mudy zakky Posted on May 22, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Update firmware lcd tv toshiba 32pb10e - Televison & Video
gemagm
Level 3:
Master:
  • Master 689 Answers
  • Posted on Jun 05, 2014
gemagm
Master
Level 3:
Master:
Answers
689
Questions
0
Helped
119843
Points
1147
How to Update Toshiba TV Firmware
  1. Plug a USB flash drive in to an available USB port on your computer and copy any files from the drive that you want to keep into a separate folder on your computer.
  2. Format the drive as a FAT32 file system. This erases all of the files currently on the USB flash drive.
  3. Click here to open the Toshiba Support home page.
  4. Click "Product Support" in the menu along the top of the home page. The Product Support drop-down menu opens.
  5. Select "Televisions" beneath Choose Category.
  6. Select your type of Toshiba TV beneath Choose Family. For example, options include 3D TV, LCD TV and LED TV.
  7. Select your Toshiba TV model beneath Choose Model.
  8. Click the red "Go" button to the right of the Choose Model section after selecting your Toshiba TV model. The product support page for that specific TV model will be displayed.
  9. Select the "Downloads" tab. If there are no downloads available for your TV model, either your won't be able to click the tab or there will be a message within the tab that says there are no downloads at this time. If this is the case, no firmware updates are available for your Toshiba TV. Check back periodically, as firmware updates are released as needed and aren't scheduled.
  10. If there is content in the Downloads section, look in the Category section for an item titled TV Firmware. If this option doesn't appear, no firmware update is available. However, if this option does appear, click the clickable link associated with the firmware. The TV Firmware Update and Release Notes dialog box appears. In this dialog box you can see the size of the firmware update file, when it was released, exactly what it addresses and more.
  11. Click the red "Download Now" button and save the file to your connected USB flash drive.
  12. Extract the contents of the ZIP file on the USB flash drive.
  13. Disconnect the USB flash drive from the computer after the firmware update file saves successfully to the device.
  14. Power on the Toshiba TV and then connect the USB flash drive to the USB port on the Toshiba TV.
  15. Wait a few moments for the "Firmware file is detected in USB" dialog box to appear on the screen. Select "Yes" to update the firmware. A progress bar displays on the screen. Be careful not to turn your TV off while the firmware is updating. The progress bar changes to a "Success!" message after the update successfully installs.
  16. Disconnect the USB flash drive from the TV and then restart the TV. After the TV restarts you can resume using the TV as you normally would.
3 Related Answers
Anonymous
  • 108 Answers
  • Posted on Jan 08, 2009
SOURCE: i updated my lcd samsung firm ware and the picture went crazy .
you need to go into the service menu and adjjust the option bytes. When you upgraged you changed them. The other solution would be to replace the main pcb
ripleymojica
Mando Mojica
  • 643 Answers
  • Posted on Jun 02, 2011
SOURCE: Toshiba REGZA LCD 32PB10E why when I play video in
Sounds like your connected component video. Try connencting with the yellow white and red cables. Also the unit might be set to progressive scan. Try dropping resolution within the player. Hope this helps.
Anonymous
  • Posted on Feb 03, 2012
SOURCE: sony bravia klv-32t400a lcd tv
YOU MIGHT HAVE A GOOD CHANCE BY CALLING 1-800-222-7669 IF TED IS STILL EMPLOYED THERE, HE'LL BE ABLE TO GET YOU ON TRACK, GOOD LUCK BOB G.
I can’t find the update file for the toshiba tv 50L2436D anyone help?
If your TV is connected to the internet, firmware will be
automatically made available.
If your TV is not connected to the internet, you can download the latest version of firmware from www.toshiba-om.net/firmware.php
www.toshiba-om.net
If you are still having problems contact the Toshiba Helpline on 0333 222 7111
http://www.toshiba-om.net/pdf/manuals/lcdtv/English/Country_Specific/L2436-4050-English-Specific.pdf
2answers
I need software for toshiba 32PB10E
google toshiba homepage with make, model and serial. If it is in stock they will sell you a new set for around $50 , tell them what o/s you are runniing
HI I HAVE TOSHBA TV 42L6200U WHEN START TV ON DISPLAY ONLY TOSHIBA AND FREEZ
Hi Nileshkumar.
You can try unplugging your TV for about 30 minutes to an hour. If this does not help try unplug the TV and leave it unplugged all night. If this does not work you have either a bad main board or firmware issue. Here is a link to the Toshiba website for your model TV, it includes troubleshooting, firmware updates, and how to update your TV's firmware. Just click on the link or copy and paste it.
Hope this helps.
http://support.toshiba.com/support/modelHome?freeText=3357897
Hi all. i got 1 toshiba led tv 32pb10e problem DOUBLE IMAGE WITH DISPLAYED RED N BLUE COLOR ONLY ON SCREEN . I TRIED REPAIRED SINCE LAST NIGHT BUT CANT . PLS HELP ME IM URGENTLY NEED REPAIR IT . TQVM
The old projector TV's are using 3 lamps for Red Green Blue....in your case the Green lamp stopped working....either the Green lamp burned or the lamp board is defective.
I have Toshiba Regza 32pb10e LCD TV & I have no color blue in my picture
If you have reset and t to factory default and this problem still persist you will need the services of an electronics technician. It is possible that the motherboard has developed a component fault
Why no ota firmware update
Contact the authorized service center for Toshiba.
Electro help
2helpful
Toshiba REGZA LCD 32PB10E why when I play video in the flasdisk, the color is just black and white .... please help me ...???
Just bought toshiba 40rv525u. worked fine for 2 days, now picture freezes on all channels. Fine for vcr and gaming theough. Checked cable on other tv's and is fine.
Sounds like firmware problem if it is still covered by warranty the manufacturer can replace or sens you a usb with firmware update on it speak to your dealer about your warranty. If not covered let me know and i try find update for you.
2helpful
2answers
I have a toshiba 42HL167. Love it but recently when the power is off iget a repeating blinking yellow light. Blinks 3 times pauses blinks 3 time pauses blinks either 2 or 3 times then stops for 25 seconds...
Yes. The Yellow LED blinking 3 times is a normal boot-up, but if it keeps doing it -- it needs the firmware "update" (which is more like a reload because it got corrupted.) The problem is, no one talks about how to do that. (there is a PDF and firmware on toshiba's website, but it lacks some crucial details.)
My friend gave me his 42HL167 after this problem started after a power event during a storm and I managed to fix it by reloading the firmware.
I posted instructions on my website at:
http://www.benjammin.net/www/pages/techtips/Toshiba-Regza-42HL167.html
Once I figured out some of the facts, it was a breeze...
3helpful
2answers
Toshiba 26LV610u TV with no sound on one channel
If you have lost sound on only one station and are using cable or an antenna directly to the TV. Look in the audio settings as most likely the SAP mode is turned on. If the TV detects a SAP signal even if there is no audio this is what you will end up with.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
