Question about Razor MX500 Dirt Rocket
I Replaced the charger port on my Razor Mx500 Dirt Rocket and it ran fine and then just stop. The charger still indicates the batteries are charge but no power. Also I went to check the fuses and manu
Any way to trouble shoot this with out buying parts I don't need. Even on the handle the lights were lit after charging. And what is with the missing fuses>
    New Friend:
    Problem Solver:
  • 16 Answers
Well if it's missing fuses obviously it won't run. When you turn it on does the green light on the throttle come on? if you have a voltmeter that would help. Are you sure the charger is good? if so you want to see 39 volts or so across all 3 batteries. Sometimes the switch contacts develop excessive resistance try shorting them with your screwdriver... if it runs you need a switch. can you hear the controller click when you turn the throttle?
Posted on May 22, 2014
2 Suggested Answers
6ya staff
SOURCE:
karinb129
SOURCE: bought a used razor mx500.
Did you ever solve this problem?
Posted on Dec 03, 2010
When charging my light stays red does that mean its charging
Some chargers have 2 LEDs (lights), some have one. Both chargers have an LED that is red (or orange) when the charger is charging a battery and turns green when the battery is charged and the charger has dropped back to trickle charge mode or off.
On the charger with two LEDs , the extra LED is normally red to indicate the mains power is connected.
Sep 10, 2013 | Razor MX500 Dirt Rocket
Our Razor MX500 won't run with out giving the motor a little help getting going. We took the motor off and hooked it to a battery charger and it works fine, you put it back on the bike and it won&
remember the motor transfer the power to the front..there no weight on the motor when you take it off..the motor can be going bad/a singnal! most people change the battery without checking the motor for wear..
Sep 14, 2012 | Razor MX500 Dirt Rocket
I have charged my MX 500 dirt rocket for 24 hours and the charger still is red. I took it off the charger and the back wheel went, but not going fast enough to stay up with both my feet off. When I hold...
The battery is probably bad. If a battery is fully discharged it can damage one of the cells in the battery. If you can replace the bad cell then it should charge correctly. Many of these batteries are made to be hard to open up and are hard to repair when they are opened. My best solution is to replace the battery and if that doesn't help then the charger is bad. When the charger is replaced then if both batteries are good then you will have a spare. I hope this helps.
Aug 15, 2011 | Razor MX500 Dirt Rocket
I can only get about 5 minutes of riding.either the battery or the charger might be broken.i relly dont know what to do.i need help
If you take the battery into a car part store like Schuck's or Napa, they will test the battery for free. They will test it to see if it will hold a charge. If the battery doesn't hold a charge, then the battery needs to be replaced. If the battery holds a charge, then your charger needs to be replaced.
May 22, 2010 | Razor MX500 Dirt Rocket
Mx500 Razor Dirtbike battery issue
you could try charging it if this dont work you will have to replace it
Apr 02, 2010 | Razor MX500 Dirt Rocket
Razor MX500 Dirt Rocket Logo
350 people viewed this question
Top Razor Cycling Experts
Lawrence Oravetz
Wayne Fraser
ray gallant
ray gallant
Are you a Razor Cycling Expert? Answer questions, earn points and help others
