The errors in computers make it miserable for their users to use them. They face so many problems when computers do not perform as intended. A very common error, which computer users can face, is the c000021a fatal system error.
This error is produced when it found by Windows NT kernel that either of the two processes Csrss.exe or Winlogon.exe has failed. Such processes could have stopped working due to many reasons like misaligned files being installed on the PC and a faulty restoration of files at the place where they were being used. In the event of such a situation, the Windows NT kernel stops the system and the stop c000021a fatal system error message is produced on the screen. This kind of a fatal exception happens when the PC can't tackle an exception and the program showing it needs to be closed.
This kind of a c000021a unknown hard error can be resolved by uninstalling the software that is not as per the needs of your PC. One can remove all the unwanted files present on the PC. An upgrade of the PC's operating system is also an alternative to restore it to its working condition and fix the stop c000021a unknown hard error.
The second solution to fix c000021a error from your computer is also very simple. You do not need to feel much hassled because of it. Just restart the computer. When the computer is booted, press the F8 button. Choose the last known good configuration and then press enter. This error generally happens when some software or hardware has been installed that is not as per the specifications of the PC. Therefore, after selecting the operating system you want for booting, the C000021a error will have been removed from your system.
However, it is better to utilize a registry cleaner software when the error still does not go away.
Windows registry includes all the information that is used by this operating system for carrying on with any operations like creation of documents. Windows Kernel uses all this information for executing the applications.
Registry cleaner software can ensure that the registry is cleaned of all the bad entries which have been causing an improper execution of files by Windows Kernel. Using this software is one of the most effective ways to fix the c000021a fatal system error. It can clean the registry without deleting any useful items from it which can lead to production of further errors.
Fix C000021a Fatal System Error is easy to do with registry cleaner. If you Scan Your Computer it will detect all the errors in your registry and safely remove them.
