Ge nautilus dishwasher soap door latch won't close.
Make sure the dial that you turn to start the dishwasher is all the way to the beginning. Sometimes my little grandson comes by and plays with it, turning it. I load, add soap and the dispenser won't close. I check the outside dial, and sure enough, set it to the very beginning and the dispenser locks in place!
The latch solenoid may be stuck in the closed position if the door won't go all the way closed and may be stuck in the open position if the door goes to the closed position but doesn't remain latched. Look at the slot that holds the door tab. It may also just be clogged with something.
GE Quiet Pro 3
hoover HFI 303D door latch not latching
replace door springs
It seems like the door is loose, not sure what the problem is. Dischwasher stops working. We press on the door and it starts working. Would this be the latch, gasket or what?
Hi, my Dishwasher din 5832 door locker is in close position. I cant unlock it or close door.
The little flapper looks normal and moves easily
When we try to close it it wont shut
