When I turn the dial to set side oven on, the light comes on but fan/ heat is intermittent. Becoming worse No heat now at all
SOURCE: Fan not coming on in fan oven Second (smaller)
fan motors seized or slow. Turn ovens on with the doors open and switch them on individually,you should see the fans turn behind rear panels, if not see if elements redden up as test if not they may be faulty also.
Hi Pauline Thomas, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?Does the fan go around at all, if so is it running at normal speed. Does heating element work at all, is the element behind the fan.
These units generally break down together, the element overheats and burns out because the fan is not going fast enough to clear the heat.
It could also be the thermostat of course, really unless you are competent and have the right testing equipment you really need a sparky to check it out.
You can purchase the spares you require from espares.co.uk, they are generally quite good prices and will send out pretty quick, most contractors will purchase for you but obviously put their profit on top.
Get back to me if you need more help.
