I turn my BENQ Projector it go on well but after some time it go off completely and it never go on again until I unplug the power cable and plug it again then the problem still persist!
SOURCE: Resetting the lightbulb in my benq projector
press and hold exit button for 3 seconds or more and OSD will pop up, then follow instructions
SOURCE: BenQ MP610 password???
Hi, i have a problem with MP610 i lost password and i can give you the code num 22654 15072 7440 9690
SOURCE: LCD shutting off automatically
Had the same problem with PB2140, during startup the lamp went off and power and lamp leds turned on. This happened after the projector fell down. I read a post there hat mentioned it was probably the power supply so i disassembled the projector. I found out that a small transistor of the power supply was torn away but it was still inside the projector. I found it, put it back and the projector works just fine. Thanks!
SOURCE: BENQ PROJECTOR
Mine needed a "fan module" replaced. The part number is 60.J8613.011.
Cost was $60, plus $100 for labour.
SOURCE: my benq projector turns on for a few minutes
if it goes through shut down mode (lamp first and fans run a while), reset the settings to factory default. while you're in the menu, check the lamp hours (under settings). if they're close to 2000 hours, replace the lamp. if the projector shuts down immediately, fans and all, you have a power supply problem. you'll need to replace it.
Resetting the lamp counter
i. Press and hold the Exit 5 button on the projector for 5
seconds to display the total used lamp time.
ii. Press Auto on the projector or on the remote control to
reset the lamp hour to "0".
iii. Wait about 5 seconds to let the OSD disappear.
