Visit us at Motorola Support Find Answers Motorola Mobility Inc for assistance with pairing your device.
Mark
Motorola Support
SOURCE: My Motorola S305 stereo bluetooth headphones' foam
Hey, this might be too late to help you, but I figured I'd share in case anyone else came across this while looking for help (as I did).
There's a small inner ring that the edge of the foam ear pads wraps around, but you can't really fit it under there while it's attached to the earpiece. The solution? I used something thin (specifically a nail file) to remove this "ring". It actually seems designed to pop on and off. I was then able to easily wrap the foam ear pad around the ring, then re-attach the ring to the rest of the earpiece.
Hope that helps!
Testimonial: "I figured this out a month or two ago, but it's good to see someone else put it online for others to find. In my case, I found a credit card worked."
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
