Samsung has a new set out that has a capacity so large, it's too big for just a 2 person household. And at that, king sized bedding is large and heavy I don't know how the set would stand up to it so I take large bedding to a Laundromat and use the hi Cap front loaders they have.
Good Luck with the search,
Cheers
Kelly
San Diego, CA
yes I would say these machines will wash this item
should be gentle cycle and max water level settings.
I can confirm kenmores xtra capacity machine does.
If material is delicate or fragile any, the large frontload
machines at local laundromats will be appropriate for this job.
hope this info will be helpful, PAUL Douglas Calif.
Your sink is likely to be glued into place, in which case you will need to carefully extract it from its surround. Begin by disconneting your water supply and removing all the plumbing connections. You probably wont need to remove the actual taps, but t wont hurt. Be very careful about using hammers as ceramic sinks do not tend to react well to them!
Sinks are made of many different materials. These include Stainless steel, Enamel over steel or cast iron, Ceramic, Plastic, Soapstone, Concrete, Terrazzo, Totianota, Wood, Stone, Copper and Glass.
